Old 09-09-2009, 08:24 PM   #1
silverado_hotrod
carb help
i have a 86 chevy k10 silverado with a 305 got 2 questions . first question is the engine has an eldobrock performer intake on it and the po had a holley 850 double pumper on it i have taken that off and cleaned the intake up and i have an eldobrock 600 cfm performer carb on it do i need the adapter plate that the po had on the intake or should i use the thin metal plate that came with carb? 2nd question how do u hook up the tv cable from a th700r4 trans to the carb?
silverado_hotrod is offline   Reply With Quote
Old 09-09-2009, 08:53 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: carb help
the 800cfm was to much for that motor right?
and yes you need a tv cable on the 700r4
i cant realy help u with the rest
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-10-2009, 11:07 AM   #3
Damien
Damien's Avatar
Re: carb help
Edelbrock sells a bracket. Here is a link to the page. http://www.edelbrock.com/automotive_...throttle.shtml
By reading Edelbrock's website, I don't think you need an adaptor. You can set the carb on the intake and open the throttle. If the throttle blades clear the manifold you should be ok.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-10-2009, 12:32 PM   #4
wydomkr
Re: carb help
I'm assuming the Performer carb. is a square bore, is the intake for a square bore or spread bore carb?
I'm thinking if the PO used the adapter with the Holley, which was most likely a square bore, then the intake must be for a spread bore and then yes, you would need to use the adapter.
Keith
1980 C-10
1981 C-30
wydomkr is offline   Reply With Quote
Old 09-10-2009, 12:38 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Re: carb help
You will not need an adapter on your Performer intake.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-12-2009, 07:01 PM   #6
silverado_hotrod
Re: carb help
ok the intake is a dual bolt patteren but its a spread bore and the carb is a square flange one place says to use the thin plate that came with it and the other says i dont need anything whos right?
