Old 09-10-2009, 06:12 PM   #1
74 C-30
Dually Pride
74 C-30's Avatar
valve covers leaking
hey guys so today I started my truck for the first time since i replaced the leaky valve cover gaskets, and it started leaking again. I'm going to pull the valve cover off again and re-clean all the surfaces and probably try a bit a gasket-in-a-tube. theyre the stock stamped valve covers. my question is does anybody have any helpful hints on how to keep the covers from leaking? thanks!
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 09-10-2009, 06:23 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: valve covers leaking
well for me Ive only used rubber gaskets and used the gasket sealer on the gasket and valve cover mating surface. I don't have a torque wrench, so I have always taken the bolts hand tight and then go one to two full turns on the bolts with wrench. and mainly make sure the out side bolts are tighter then the others because that seems to leak more then the other side. I am sure what I do is not by the book right, but it does work for me.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 09-10-2009, 06:27 PM   #3
85Bowtie
85Bowtie's Avatar
You need to bolt them on, run the engine, then tighten them again. The gaskets get softer when the engine is hot, so you have to go back and take the slack out thats there. Just use a 1/4 drive ratchet and hold it by the head and just give it a firm turn until it tightens al the way, and tighten from the middle bolt outward criss-crossing. Then repeat the pattern until they're tight
I had to do this a couple of times on the 318 in my cop car.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 09-10-2009, 06:42 PM   #4
79gmcc15
79gmcc15's Avatar
what middle bolt? isnt there only 4 bolts on a SBC? they are at the corners, right? I know the vortec motors had the ones on top...
RIP ELJAY
Old 09-10-2009, 07:51 PM   #5
3r!c84
Badass
3r!c84's Avatar
just do a x
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-10-2009, 08:09 PM   #6
3r!c84
Badass
3r!c84's Avatar
do u have this?
-00 Saturn 5spd
1/4:13:90
Old 09-10-2009, 09:21 PM   #7
85Bowtie
85Bowtie's Avatar
Yeah thats right, haven't looked at one in awhile, maybe thats why they leak.....
Chrysler uses 5 bolts, bottom middle, 2 diagonal across at the top, then 2 at bottom corners, and they don leak.
Just cross them then, but you have to retighten them a few times to seat right.
Old 09-10-2009, 09:46 PM   #8
1984 swb chevy
1984 swb chevy's Avatar
you should take your valve cover off and look at the bolt holes. If the valve covers were over tightened the sealing surface of the valve cover may not be flat. Check the area around the hole. If it isnt flat tap it down with a small hammer to get the surface area flat. When you put it back together do not over tighten them.
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 09-10-2009, 10:02 PM   #9
70k52wd
Blaze-Air
70k52wd's Avatar
What he said is most likely the problem. Hold the edge of the cover upside down on a flat edge and carefully tap until the surface is flat. Or, I use a piece of 2x4 wood the length of the cover flange, then one good whack will get it nice and flat.
70k52wd is offline   Reply With Quote
Old 09-10-2009, 09:08 PM   #10
74 C-30
Dually Pride
74 C-30's Avatar
yes i have the little load spreaders. after i ran it once i tightened down all the bolts again, and ran it again and she still leaked, but it took awhile to start leaking, i'll recheck the bolts and tighten them like 79gmcc15 said, then if all else fail, i'll take the valve cover off. btw its a cork gasket
'94 Ford Ranger
Old 09-10-2009, 09:47 PM   #11
silvereagle07
silvereagle07's Avatar
I agree with 1984 swb chevy. Check the bolt holes. I scuff the valve cover, where the gasket sits, with a Scotchbrite pad and apllied "gorilla snot" (trim adhesive) between the gasket and the cover. It will help hold the gasket in place. That method always worked on stock or chrome valve covers for me.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 09-10-2009, 09:53 PM   #12
74 C-30
Dually Pride
74 C-30's Avatar
as posted above, stock stamped with cork gaskets
'94 Ford Ranger
Old 09-11-2009, 12:03 AM   #13
ghettoluxury
ghettoluxury's Avatar
Put rubber in! cork will always leak
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-10-2009, 10:06 PM   #14
74 C-30
Dually Pride
74 C-30's Avatar
ok guys thanks for all the ideas! hopefully once this is solved, for the first time in 12 years I'll get the ol' truck inspected and on the road!
'94 Ford Ranger
Old 09-11-2009, 01:48 PM   #15
Rons86
Rons86's Avatar
All the things mentions above are great and I agree with them all. Another thing to keep in mind is that the crankcase builds pressure and needs ventilation. Do you have and vents on the valve covers? I say this because of a similar experience with non vented valve covers that I could not get stopped leaking. We fnially bought some with vents and the leaking stopped immediately bacause of crankcase pressure.
Rons86 is offline   Reply With Quote
