09-13-2009, 08:46 PM | #1 |
Had "one of those days"
I go to a local car show today and as I was backing in another guy says my left brake light wasn't working. I checked all the lights just a couple of days ago! I only had a 10 in one scewdriver so I swapped bulbs from side to side and still no left brake or directional. I'm kind of an anal person so it was on my mind most of the day but I enjoyed the show. When I got home I grabbed my test light, the bulb in it was burnt out so I grabbed a meter. I put a new tilt column in a couple of weeks ago (have had it for many months, just got around to installing it) so I figured I would test at the curved connector since it was the latest "change". I tested on the good side (right/green wire) and the meter showed correct voltage. I checked the side not working (left/Yellow) and got the same reading, hmmm!
So I start at the back checking for voltage at the lamp, none. At the crossmember plug, none. At the firewall plug, none. I continue to check the good side to make sure there are no abnormalities using the meter and I get a good 12Volts on the good side? Everything looks good and still no left brake/directional so I follow the harness and don't see anything. The front is working so it can't be the flasher. I decide to go back to the curved connector and I am getting poor reading on the harness side of the plug but 12 volts on the turn signal/hazard side? I take the connector apart, remove the pins (messed up the harness side pin, figures). Something doesn't seem right and I am getting frustrated. For the hell of it I grab the turn signal switch from my non tilt column and plug it in. YUP you guessed it, it works. 3-4 hours wasted (I did put dielectric grease on all my plugs). I don't understand why I would get voltage readings at the plug but it wouldn't work (maybe the meter takes a lot less voltage than a flasher/lamp? Well I need a turn signal/hazard switch for my newly rebuilt tilt column. I also have to fix the connector it plugs into. Oh well thought I might give some of you a laugh at my expense. Even I think its amusing............NOW. One of those days. Tommorow I think I may try to dye some seat belts, wonder what I'll screw up then? |
09-13-2009, 08:51 PM | #2 |
Re: Had "one of those days"
I discovered Napa carries the switches. I don't remember the price, but it was reasonable... just fyi...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
09-13-2009, 09:26 PM | #3 |
09-13-2009, 09:17 PM | #4 | |
Did you enter your truck in the show, or was it just a cruise in?
09-13-2009, 09:25 PM | #5 |
It was a show but no real classes. I didn't expect to win anything. I like to see all kinds of cool vehicles and I love to watch and meet people. Saw some people I hadn't seen in a while. All in all a good day. I do have gloves but fear something will get dyed that I don't want dyed!
09-13-2009, 11:31 PM | #6 |
I think it may have had an adapter. It was over a year ago.
