![]() Join Date: Sep 2007
air bags hitting the bump stops!!!!!
I just added front air bags (dominator 2600) in the front end and at the same time swapped out to 72 control arms and hub assy`s for disk brake conversion. Now my bags are hitting the bump stop mounts on the lower control arms when deflated. have you guys run ito this before? I thought I did all my research before tackling this but I never read about this.
Am I gonna have to cut these off or is the bag not sitting right in the lca cup or??????
1967custom |
Re: air bags hitting the bump stops!!!!!
yeah ... most folks cut the bump stop mount off the lower a-arm.
dang man!! nowI gotta see about removing that lca again to cut it off. its always something
1967custom |
![]() Join Date: Sep 2006
Actually, I asked here several months ago if I needed to cut mine off and the answer I got was a resounding no. Go figure. Mine's not back together yet to see how it works.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
theres a downward bend at the bump stop mount that the bag hits and it doesnt look like the bag is catching on the metal but rather resting on it. Ill take a pic for you guys and post it in the morning.
All input helps guys!!!
1967custom |
Yep, no bumpstops here.
Are you laying that thing out, or plan to? That's the same bags as me, and they are HUGE!! I had to cut, and keep cutting lol to get it to lay flat.
I've got soo many rides I forget, but don't these trucks front bumpstops just pull out? From on the truck, can't you grab and pull?
Superbad
I take the bump stop brackets off too.
67-72 parts collector,…
![]() Join Date: Nov 2002
Cut it off while its on the truck. A sawzall or a grinder with a cut-off wheel will work. I usually leave the steering stop in place. Some people take the entire bracket off.
Then grind any sharp edges smooth.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-14-2009 at 08:27 PM. |
low n' slo
![]() Join Date: Mar 2009
ive got the same bags and will be putting them in within the next month or so. if you take the old ones off, can you put a smaller one in there or will those get in the way too? michael bustamante, can you post some pics of hit hitting?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 09-14-2009 at 09:04 PM. |
michael , did you ever get some pics?
i know this is an older thread but i am about to encounter the same problem on my '69 and was about to post a similar question. I have stock control arms and i am going to use dom 2600's. it looks like the bags might hit the hard bump stops and it looks like i need to remove them to get it to lay out. Is this the case? |
i would remove the bumpstop and bracket. ive had to do it on all my static dropped trucks.
One day.....
I cut mine off. I had always heard that you have to cut them off. I'm running Slams RE-7's and supposedly they have an internal bump stop.
DZL1. |
#15 |
I guess i am going to need to see how low its going to with the bags in.
i am running 2.5 drop spindles. |
#16 |
Heres the pic I got. As you can see, Its pretty obvious the bump stops gotta go. I ended up cutting them off with a sawzall and grinding down smooth.
1967custom |
#17 |
One day.....
Heres a pic of mine:
DZL1. |
#18 |
low n' slo
I cut mine off all the way..haven't hit the road in yet yet and probably won't until next year. u guys gonna run any bumpstops?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#19 |
dzl1 how do you like your slams? i notice you arnt running shocks, hows the ride?
#20 |
thanks for the pics. thats exactly what i needed to see.
how low can you go like that? i am planing on running some kind of bump stop. dont know what yet |
#21 |
drag it like you stole it
You have to run shocks. The bag itself is just a spring. Just think about taking the shocks off a coil spring truck and how it would ride.
negative camber //LA\\ |
#22 |
No bumpstops for me, they will have air in them when in motion. Stock lcas with plates and cups wasn't very low at all on my truck.
#23 |
One day.....
I am running shocks. you just cant see from the angle picture was taken. I like my slams very much, no complaints. One other thing, I also had to cut about 3/4 of an inch of the ends of the front sway bar. when aired out, the ends would rub on the bag.
Hey Michael Bustamante, I dont see a sway bar on yours? DZL1. Last edited by DZL1; 10-24-2009 at 12:14 AM. |
#24 |
Wide n'Low
![]() Join Date: Jan 2007
Cut mine off, and I am running upper and lower plates from jlaird here on the board.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#25 |
One day...
I used a spot weld cutter an drilled the bracket welds out and used a air hammer to knock the bracket of then ground the control arm smooth.
