Old 09-15-2009, 09:10 AM   #1
redsean
redsean's Avatar
Unhappy 60-62 airride?
i have look and looked. (the search is not worked for me for weeks)
i need to know what all u guys have been doing to get drop spindal and air bags on the front of a 60-61. hell if you know of the thread just show me the way
PLEASE>>> HELP
redsean is offline   Reply With Quote
Old 09-15-2009, 05:38 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 60-62 airride?
try some of imperial customs posts, or pm him, he has done 2 early trucks.
dropmember also sells a kit for the 60-62.
the cheap way i think is to use the entire crossmember out of a 67-87, and then airride that.
Old 09-15-2009, 06:19 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: 60-62 airride?
Buy dropped spindles for your truck and upgrade to disc. Pull out your torsion bars (press out, actually) and put plates on the control arms and upper frame section as if you were bagging any other truck.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-15-2009, 06:25 PM   #4
SixOneC10
SixOneC10's Avatar
Re: 60-62 airride?
You can convert a torsion front end to ride on bags. If you can measure, cut and weld its not hard. The drop members are $$$ now you can get drop spindles for 60-62 trucks but you havw to upgrade to later model disc brakes. I think the cheapest would be to fab the bag mounts in your front end and get drop spindles.
SixOneC10 is offline   Reply With Quote
Old 09-15-2009, 07:00 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 60-62 airride?
Plate the lower arms as PT stated, and you piece together a drop spindle/brake kit using 88 and up brake parts.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-15-2009, 11:06 PM   #6
Captainfab
60-66 Nut
Re: 60-62 airride?
I don't believe that will work with the '60-'62 front suspension. Unless you know something I don't.
[QUOTE=ChiefRocka;3520260]Plate the lower arms as PT stated, and you piece together a drop spindle/brake kit using 88 and up brake parts.[/QUOTE]
Old 09-16-2009, 11:09 AM   #7
redsean
redsean's Avatar
Re: 60-62 airride?
thanks guys for the info, i really need to go pretty cheap or i would love to go with a dropmember.
Old 09-16-2009, 02:56 PM   #8
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: 60-62 airride?
Cheap and Dropmember dont go together. haha
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
