09-16-2009, 04:19 AM | #1 |
what shocks
my question is what shockers are people using on static drop and bagged trucks ?
09-16-2009, 08:52 AM | #2 |
Happy to be here
Re: what shocks
Try these. They were located right below your post...
Shock absorber recommendations? LINK Need some rear leaf shocks for 4" drop.- LINK what shock ( for the millionth time??) LINK Shocks for a bagged front end- LINK kyb shocks/ part numbers- LINK
09-16-2009, 02:01 PM | #3 |
Señor Member
Re: what shocks
Or, in Australia, "right ABOVE your post."
09-16-2009, 09:44 PM | #4 |
Re: what shocks
Thanks N2TRUX I realised after I hit the button .. is there any reason why i can't post a reply to my thread ??? cheers from down under
09-16-2009, 11:16 AM | #5 |
67-72 parts collector,…
Re: what shocks
Ray Rust,...
If your question is about "Brand of Shock",... alot of people use KYB's, Belltech, or Bilsteins. As far as application,... a mild bag job using stock upper and lower a-arms, and trailing arms,... you can use the same length shocks as you would use for a 4/6 drop. It's when you get into tubular a-arms and 3-link or 4 link rear suspensions, that you need to contact the manufacturer of the components for the proper shock. What did you have in mind for your suspension? Static or bags?
09-16-2009, 09:48 PM | #6 | |
Re: what shocks
09-16-2009, 10:27 PM | #7 | |
Re: what shocks
6" of drop up front w/only cut springs doesn't sound right. How many coils have been cut off the spring?
09-16-2009, 10:38 PM | #8 |
Re: what shocks
Scoti .......just bags on the rear so your idea might be the way to go ... thanks Ray
09-16-2009, 10:43 PM | #9 | |
Re: what shocks
What about the front? Do you know how much coil was cut off the springs?
