09-16-2009, 09:57 AM | #1 |
Loving the Jimmster
72 jimmy top
Will any other years fit the 72 jimmy top?? I am sure that 67-72 are the same but what about newer years?
Thanks vance |
09-16-2009, 10:29 AM | #2 |
Re: 72 jimmy top
No such thing as a 67 or 68 top, first year for blazers/Jimmies is 1969.
A 69-72 top will fit all years but there's also two version's of hard tops. They made a double walled top 69 thru 71 but had a single walled top as an option in 71 and OEM in 72. |
09-16-2009, 11:07 AM | #3 |
SKINNY TIRES RULE!
Re: 72 jimmy top
Actually, the first year for the Jimmy was 1970.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-16-2009, 11:14 AM | #4 |
Re: 72 jimmy top
09-16-2009, 12:20 PM | #5 |
Loving the Jimmster
Re: 72 jimmy top
So they made a blazer in 69 and a jimmy in 70? also you say oem top on a 72 is single walled, but mine has a double top, does that mean its not oem?? By the way thanks for all info, there is much to learn!!!!!!!!!!!!
09-16-2009, 04:16 PM | #6 |
Re: 72 jimmy top
I believe the single wall top was an option starting in '72. I've not come across a single wall on a '71 that was original. just my .02.
'73 through '75 tops will not work. Look at the SPID on your glove box door. It should tell you what top yours had from factory. From reading all the wonderfull posts through the years it seems that some '72s had only double wall holes, some only had single wall holes, and some had both holes for single and doulble wall tops. Go figure.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." Last edited by 71jimmy; 09-16-2009 at 04:22 PM. |
09-16-2009, 09:34 PM | #7 |
Re: 72 jimmy top
Sorry but their was no single or double wall option. Just hard or soft. When they changed from double to single in 72. They used up all their left over double wall tops first. So if you have a double wall on a 72, good chance it was made early in the model year. Like mine.
09-17-2009, 12:54 AM | #8 |
TILT COLUMN GURU
Re: 72 jimmy top
Mine has single wall but has holes for both. does have plug for dome lights so I believe it came from factory with single since double wall has no dome lights.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
09-17-2009, 03:54 PM | #9 | |
SKINNY TIRES RULE!
Re: 72 jimmy top
Here's my SPID
