09-16-2009, 10:25 AM | #1 |
Blazer Body Mount Bolt Measurements
Not exactly hi-tech imagery but I had em out and it's always asked, so here ya go.
09-16-2009, 10:26 AM | #2 |
Re: Blazer Body Mount Bolt Measurements
...and position 5
09-16-2009, 11:00 AM | #3 |
New Member
Just a heads up for anyone replacing their mounts with poly instead of rubber. I just did this and only a few of the stock length bolts worked. The poly mounts will require longer than stock bolts in almost every position. I think I was able to only use 2 or 4 stock length bolts, I can't remember for sure.
09-16-2009, 11:15 AM | #4 | |
Thanks for posting up what you've run into. Last edited by vtblazer; 09-16-2009 at 11:15 AM. |
09-16-2009, 11:23 AM | #5 |
Remaining parts to each position aside from the rubber body mounts.
09-16-2009, 11:24 AM | #6 |
...and position 5.
09-16-2009, 11:52 AM | #7 |
where did you get the kit from?
EDIT - After Googling the PN#s looks like the LMC numbers... Last edited by lks dcvn; 09-16-2009 at 11:55 AM. |
09-16-2009, 11:56 AM | #8 |
Wide n'Low
Thanks! good info that always seems to be overlooked..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
09-16-2009, 04:24 PM | #9 |
Great stuff VT.
Moderators please post to FAQ section.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
09-16-2009, 05:20 PM | #10 |
The set I got from Tim is what I would consider to be "complete".
There are other vendors out there selling...lets just say "not so complete" sets. Talked with another blazer guy who just received one of those 'other' sets and it was missing these items: * the square washers for the core support * the 7/16 core support bolts * ALL 4 concentric washers * and both position #2 bolts were M.I.A. At a premium price too. |
09-16-2009, 05:37 PM | #11 |
What does the kit from Tim cost - I checked his site - but couldn't locate it in the product listings.
Thx for posting this (BTW) - |
09-16-2009, 05:41 PM | #12 |
You're making it too easy for rookies
We had to bleed,sweat & cry to get that far ahead in replacing them. I probly made 5 different trips to the bolt store to do mine hahaha Just messin ~ Good for the community When are you gonna ship me your tube doors? Not being a "harcore" wheeler anymore you don't need um
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
09-16-2009, 06:01 PM | #13 | ||
The incomplete kit in the pic was over $200.00 though. Quote:
Yeah, newbs have it to easy now for sure and still they don't bother to look anything up. Sorry bud, tube doors went with the blue blazer. Want me to build a pair for ya? Last edited by vtblazer; 09-16-2009 at 06:02 PM. |
11-24-2009, 07:48 AM | #14 |
Bump incase some missed this and are wondering.
11-24-2009, 09:00 AM | #15 |
Future TOTM Winner
I'm wondering why it isn't in the FAQ section? Glad you brought this back ttt.
I replaced mine a couple years ago with a poly kit but I didn't get the concentric washers. Did I screw up? Why does it need the concentric washers? I have everything pretty torn apart at the moment, should I add them?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
11-24-2009, 09:13 AM | #16 | |
They say a picture is worth a thousand words. |
11-24-2009, 09:47 AM | #17 |
Addicted user
Thanks for the great info!
Now... is the body mount kit the same for the 2wd and the 4x4 blazers?? I am having trouble finding a kit that says it is compatible with the 2wd blazer.. thanks |
11-24-2009, 09:50 AM | #18 |
11-24-2009, 10:34 AM | #19 |
Future TOTM Winner
So the answer is "Yes, I should get them" looks like it keeps the body from shifting from side to side. Thanks Kurt, as usual you have made me realize that I need something that I didn't even know existed.
11-24-2009, 10:38 AM | #20 | |
...well I'll take that as a 'good' thing. The factory didn't use the washers but it seems like a good idea, can't hurt. |
11-24-2009, 11:17 AM | #21 |
It (offset washer) basically acts to lock the carriage bolt to the floor so you can tighten them down without welding the head to the bed.
02-06-2010, 12:12 PM | #22 |
VT what grade are those 3/8 bolts ?
02-06-2010, 12:29 PM | #23 |
02-06-2010, 03:19 PM | #24 |
Great reference!!! Funny, that I found this not even 10 minutes after I order my set from LMC???
02-07-2010, 02:36 PM | #25 |
Anyone know what the factory torque specs are on these??
