72 dis brake booster set up f/s
![]() it comes with brackets and propor valve was working fine when took off $75.00 plus ride.
i have 67/72 chevy truck parts f/s. |
Re: 72 dis brake booster set up f/s
Will you sell brackets separate? If so how much?
Need vac unit from a 3/4 ton or 1 ton - is this such a unit or is it from a 1/2 ton (looks to be 1/2 ton). If it is larger unit, could take it for less without brackets which you could sell to other party - still would need the push rod components. Thanks for any info.
CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
olebeater i want to sale it altogether.
cccc it came off of a 1/2 ton.
Isthis set up still available?
it's [SOLD]
