09-18-2009, 12:17 PM | #1 |
difference in centerlinks??
was there a difference in the centerlinks on 1/2 ton 2 wheel drives? i thought i have heard a few mention they changed in 71 when they changed over to disk brakes? thanks
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
09-18-2009, 01:07 PM | #2 |
Retired Air Force Veteran
Re: difference in centerlinks??
Yes, there is a difference. The center link used on those with drum brakes (67 68 69 70) is different then the center link on those with disk brakes (71 72). When I changed my 69' Shortbed to disk brakes (used all 72 front end parts) I went to the local junk yard and found a center link from a 72' and paid $10 bucks
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
09-18-2009, 01:24 PM | #3 |
Moderator
I am curious....what is the difference?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-18-2009, 01:42 PM | #4 |
There is a different taper angle between the two and seems the hole size is slightly different. If you try to use the 71/72 inner tie rods on the earlier years center link you risk causing excess play.
09-18-2009, 03:05 PM | #5 |
Moderator
I see....is the center link also "bowed" slightly? I have seen several that look that way, and was wondering if this was normal, or the result of an accident?
09-18-2009, 03:12 PM | #6 |
406 Powered
As of today i finished my five lug swap. The outer tie rods are also different. I bought a whole center link with inner and outer tie rods and all the parts attached and just swapped everything out. Easy swap.....
70 GMC 68 c10 2002 silverado 72 4x4 |
09-18-2009, 03:23 PM | #7 |
Moderator
Is the center link bowed or straight?
09-18-2009, 03:34 PM | #8 |
406 Powered
It is bowed a little on the end.....
09-19-2009, 08:17 AM | #9 |
badpurplechevy, were did you get the center link from? was it new or did you pick up a used one?
09-19-2009, 09:02 AM | #10 |
406 Powered
I live in n.c. and got it from daves truck parts in claremont,n.c. He is a super stand up parts dealer.....
09-19-2009, 09:03 AM | #11 |
406 Powered
If they allow numbers given out on here let me know and ill give it to you....
