Old 09-19-2009, 01:59 PM   #1
BillyDeluxe
BillyDeluxe's Avatar
an idea how to lower rear leaf suspension
Hi folks.
I bought a 65 C10 2 years ago from Arkansas. It has a modified rear axle with leaf suspension. I guess it is a Blazer axle.
Now i try to lower my truck and have no idea how to do it. Can you give me your advice or howto's or even pictures for a better understanding. Maybe the best way is to build in a coil spring suspension again. I don't know.
Thanks alot
Greetings from Germany
Andy
BillyDeluxe is offline   Reply With Quote
Old 09-19-2009, 02:14 PM   #2
Martin64
Martin64's Avatar
Re: an idea how to lower rear leaf suspension
Put lowering blocks between the spring perches and axle housing at the u-bolts (assuming the axle housing is sitting on top of the springs as opposed to the springs on top of the axle housing).
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 09-19-2009, 02:19 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
You can use the traditional shackle, I havent seen hangers for these trucks. Mite be able to relocate the hanger higher on the frame by redrilling the holes The easiest and cheapest route is to use a flip kit with puts the axle on top of the leaf and gives you about 5'' (estimated) drop.
I met a guy who used S10 leafs on his truck, and it was low. It's possible to adapt 73-87 stuff the the frame but the leaf springs are a different width. Ours are narrower by a 1/4'' I think. Not sure whats out there for 67-72 leaf trucks.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-19-2009, 02:24 PM   #4
Eagar1
You can also take out some of the leafs, or take them to a spring shop and have them re-arced, but the axle over the spring give you the most if yours isn't that way already. I saw where one guy got an adapter to widen the lower mount and moved his upper mount outside the frame and moved it up.
Eagar1 is offline   Reply With Quote
Old 09-19-2009, 03:58 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
If you want a mild drop...then I would pull a few leafs and combine that with a shackle....
Next would be an axle flip with a small bolt-in notch to retain a ride.
Obviously, the best would be convert back to TA's !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-19-2009, 07:34 PM   #6
muddpile
muddpile's Avatar
On my 72 I flipped the axle on top of the leafs using an inexpensive kit from DJM. Dropped it about 5 1/2", no C-notch (although it will get one as the axle hits the frame). I will be adding a 2" shackle as well for a healthy 7 1/2" rear drop. It is definitely possible to be low easily with a leaf truck.
muddpile is offline   Reply With Quote
