09-19-2009, 05:35 PM | #1 |
Which 9" rearend is best?
I have been thinking about building one of my trucks with a big tire on the back. You know a big M/T. I have some of the stuff already to make my ladder bar setup but will have to get the 9 inch rearend soon. I understand that the third members can be taken off pretty easy and swapped out for another gear ratio. Which are good gears to punish and to also take out in the highway?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
09-19-2009, 09:38 PM | #2 |
Re: Which 9" rearend is best?
need to know your tans and what tire size you plan on running?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
09-20-2009, 04:13 PM | #3 |
actually im kind of in the same boat, plan on pulling a housing and centre section off a rig in the junkyard.
as for the housing is there a certain truck/car with certain dimensions to look for? and as for the centre which stamping do you look for? i know they made a few different ones. (truck will have tt-6.0L 4L80E trans) |
09-20-2009, 07:21 PM | #4 |
Check some older f150's, they had the nodular center and big bearings.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
09-20-2009, 07:22 PM | #5 |
mini truck racer
I perfer the 73-79 F-150 truck housing , i used a Bronco and sold the 3.50 center with trac-loc to offset the cost . They have big bearings on the axles and the housings have the extended support . You can bolt explorer discs off an 8.8 on them also . As for center and gears , i used a stock truck with a Richmond gear . I went 6.20's @ 3200 #'s with this combo and Moser 33 spline axles and a full spool . I have been told the strange nodular is the way to go .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 09-20-2009 at 07:24 PM. |
10-04-2009, 01:38 AM | #6 | |
10-04-2009, 07:30 AM | #7 |
mini truck racer
Here is a link to Speedway's write up . All these parts are readily avaliable from local salvage yards for cheap . The rotors will have to be redrilled to your specific pattern , as they come 5 x 4.5 small Ford car pattern ( which i had on the Luv ) . The explorer brakes bolt to the big bearing 9" . These brakes have a small drum inside the rotor for the e-brake similar to a 4th gen Camaro .
https://www.speedwaymotors.com/images/pdf/910-31938.pdf
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 10-04-2009 at 07:55 AM. |
10-04-2009, 07:44 PM | #8 |
(for a nine inch)
You can also use rotors from a AMC Eagle, with metric car front calipers along with the cheap weld on brackets from speedway. You should be able to do it for under $100.00. but you may have to turn the axle down on the flange (largest diameter), depending on axles used. we ran these on stock cars for a long time... this is 1/6th the cost of wilwood 4 piston kit cost which i just purchased, depends what your budget is.... just another idea. rotors $12-15ea, calipers $18-22ea w/bolts, brackets $5ea, pads $25 or less |
09-20-2009, 08:24 PM | #9 |
I want a fabricated housing under mine bad!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
09-20-2009, 08:34 PM | #10 |
mini truck racer
I am going to try narrowing 2 truck housings within the next few weeks I am helping a buddy on one and another Luv is in the near future for me .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
09-21-2009, 11:24 PM | #11 |
Don't do it build a full size and a big motor!
10-02-2009, 01:05 PM | #12 |
mini truck racer
Can't afford them big motors , and i have a nice pile of small motor parts on the garage shelf . Just need pistons and machine work .
09-21-2009, 11:05 PM | #13 |
At the body shop.
The housing im using is out of a 79 f-150 we narrowed one side to center the pinion. And built the center section off EbAY
10-10-2009, 04:32 PM | #14 |
Do you know the final width of the housing once you narrowed the one side to center the pinion?
10-10-2009, 07:39 PM | #15 |
At the body shop.
Flange to flange? or wheel mount to wheel mount... Either way ill have to dig for it. But i have both. it ended up 1" narrower than my 12 bolt because of wheel backspace issues
" That didnt make it any newer " " Dont antique the equipment " |
10-10-2009, 07:42 PM | #16 |
That's what I needed to know. I was hoping it would equal 1" each side; 2" over-all (that's what I'm wanting).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-10-2009 at 07:43 PM. |
10-03-2009, 09:41 AM | #17 |
Champagne Taste on Beer Budget
I need to do this swap as well.
That way I can switch out carriers if going on a long trip.
Coming Soon: Project 1970 Country Truck |
10-10-2009, 11:33 PM | #18 |
At the body shop.
Memory says 2 1/4 or 2 3/8 narrower.
11-21-2009, 08:41 PM | #19 |
so ive found lots of 9" around but not sure which one to go with as some places dont have what the rear was pulled out of. is there a way to tell if the housing has the big bearing ends without tearing one side down?
and what overall width are we looking for? the measurement off my stock 12bolt was around 145cm flange to flange if memory serves me right. the offset centre on the 9" also has be concerned. is it something that i should be concerned about? Last edited by noonzor; 11-21-2009 at 08:42 PM. |
11-21-2009, 11:34 PM | #20 |
Turbo Guy
Has anyone done the swap to a 9" without having to narrow one side to center the pinion? I too am looking at doing a 9 instead of fixing my 12 bolt
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
