Old 09-19-2009, 08:38 PM   #1
NorCalTank
Measurement Help
I thought I saw these on here before but I could not find them when searching.
I am getting ready to cut into the floor and rockers and I need some measurements before I start to brace everything. I appreciate any help.
Need A,B and C measurements and anything else you think would be helpful.
NorCalTank is offline   Reply With Quote
Old 09-20-2009, 01:11 AM   #2
Malibu 496
Junior Member
Malibu 496's Avatar
Re: Measurement Help
Here is a link to the thread with those measurements.
http://67-72chevytrucks.com/vboard/s...g+measurements
1970 blazer, street/strip project
1963 ford fairlane sports coupe 50,000 original miles
Malibu 496 is offline   Reply With Quote
Old 09-20-2009, 01:56 AM   #3
DURRTY
USMC
DURRTY's Avatar
can you put the top on? It might be easier then you can put the doors on (and off a bunch of times....)while your working on it to check the lines.
Semper Fi
DURRTY is offline   Reply With Quote
Old 09-20-2009, 06:03 AM   #4
vtblazer
vtblazer's Avatar
Read the thread...just don't look at the pic, the bottom door measurement is in-correct in the posted picture.
vtblazer is offline   Reply With Quote
Old 09-20-2009, 06:17 AM   #5
vtblazer
vtblazer's Avatar
Need A, B and C measurements and anything else you think would be helpful.
Make sure your body mounts are in great shape prior to any re-insallation of metal, if they're not replace them with new.
Here's some measurements I took last week for another board member from my untouched 69.
Your 'A' measurement:
Your 'B' measurement:
Your 'C' measurement:
Here's a couple so you can check your winshield frame angle too:
* Note where the plumb-bob string is hanging from, so your accurate when trying to match the numbers.
Old 09-20-2009, 07:42 AM   #6
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Hey Kurt, are you sure you're not a plumber? I saw the Kohler box and the plumb-bob?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 09-20-2009, 08:01 AM   #7
vtblazer
vtblazer's Avatar
Yep sure, the box is the same one you've made mention of a couple times now and from time to time, us 'lectricians have the need to drop a 'bob' too ya know.
Old 09-20-2009, 10:35 AM   #8
-Greg72
-Greg72's Avatar
Good Stuff!!
I'm printing these off for the shop now.
The only caution I'd make is that the "plumb bob" measurement will only be valid if the tub is 100% level to the ground. Otherwise I'm sure it could easily be off by 1/4" or more in either direction.
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 09-20-2009, 11:19 AM   #9
vtblazer
vtblazer's Avatar
Originally Posted by -Greg72 View Post
Good Stuff!!
Really good point to remember, pic shows the blazer floor orientation when those where taken.
Old 09-20-2009, 10:47 AM   #10
NorCalTank
Awesome, that is excatly what I needed. Thanks!
