Old 09-20-2009, 12:27 PM   #1
Rob73-87
Rob73-87's Avatar
Question Idle in "drive" problems...
Hi everybody,
I have problems with my freshly rebuild 305 ci in my truck. When the engine`s idling and I shift to "drive" or "reverse" the engine nearly dies (normally it does )
I checked the engine timing - it`s 9° BTDC - so just fine for an engine with a mild cam and so on.
I didn`t discover any vaccum leaks ....?
I really hope some of you have any suggestions
1982 C-10 SWB (soon dropped, 383ci, but restored stock appearance)
1984 C-10 LWB, dropped, custom paint
1996 Plymouth Voyager (Daily Driver "The Mule")
2008 Caliber R/T (Daily Driver)
Rob73-87 is offline   Reply With Quote
Old 09-20-2009, 01:07 PM   #2
jd74c-10
Re: Idle in "drive" problems...
what rpm is your idle set at. you might need to set it a little higher.
jd74c-10 is offline   Reply With Quote
Old 09-20-2009, 02:13 PM   #3
project_77
also,
what kind of carb are you running? it could be that the idle screws are to far out and you're not using enough of the idle screw itself.
what is your total timing at?
project_77 is offline   Reply With Quote
Old 09-20-2009, 02:30 PM   #4
Rob73-87
Rob73-87's Avatar
to be honest I couldn`t find the original GM specs for that `79 305cui motor - I thought "must be between 700 and 800 rpm when setting timing..." - is that right ?
does anybody have that smog sticker underneath the hood for a 305 motor ?? Maybe that would help....
Originally Posted by project_77 View Post
also,
I have a brand new HOLLEY Street Avenger w/o choke (!) - what do you mean with "not using enough of the idle screw itself" - right know I´m confused I think.....
Old 09-20-2009, 03:20 PM   #5
LONGHAIR
How much of a "mild cam" are you running?
It sounds to me like the converter is too tight. This puts more "load" on the engine when it is idling in gear, so it drags the idle speed down.
If you simply raise the idle speed, it will be too high in park. This causes banging and jerking when you put it in gear...
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-20-2009, 03:30 PM   #6
Rob73-87
Rob73-87's Avatar
well, the cam is the CompCams XE 262 (new) and the converter is a B&m Holeshot 2000. Comp. ratio is 9,8 : 1 with flattop pistons - distributor is bone stock HEI with stock coil - Edelbrock performer manifold - Dynomax headers ....
Old 09-20-2009, 06:22 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Are you setting your timing with the tranny in gear? The 600 to 700 RPM recommended is in "DRIVE" not in "NEUTRAL or PARK". The timing could be advanced to 12 degrees, without issue and you may find better fuel economy with that change. If you are running the carb without the idle compensator that many carbs have on them to allow for a faster idle and then drops the RPMs tp a lower setting for shutting off the motor, then you will have to adjust for your tranny's response to the change in the engine's RPM with the idle speed screw.
The cam could be putting you up against your convertor's stall speed and causing some of your issues. Adjusting the idle speed up will take you to a condition of transitioning from the idle circuit to the power circuit in the carb, this is a mess that can be taken care of by changing the converter to a high stall. You have built the engine to a point that the factory settings are out of the norm, so you have to adjust to what you have in your truck.
You did not say what you have for a carburetor.
Let's try something to set your carb up for success. Do you have a vacuum gauge of any kind---or can get one. If you can get a vacuum gauge, this will allow you to set your carburetor more efficiently and make your idle air/fuel mixture work best.
Start by setting the idle air screws at 1 1/2 to 2 turns out.
Connect the vacuum gauge to the intake manifold (So that it is reading a good vacuum signal)--preferrably not to the carb. Take the first idle air screw and turn it inward to the stop (watching the vacuum signal for change) and then back it outward slowly until you see your vacuum signal increase to it's maximum number acheived. Now do the other air screw, the same way. Once you have adjusted the screws to a max vacuum---do the screws ONE MORE time to get the most effective setting you can get. Once completed --- turn the screws inward 1/8 of a turn and your are adjusted to the best air fuel setting you can acheive with your carb.
Check your timing and adjust to a point that the engine is getting the best RPMs but not detonating (pinging on acceleration) or running on (dieseling) when shut off. I set my engines with a tming light that has an "Advance setting feature", and that allows me to adjust timing to a "Total" setting. This is not necessary, but adjusting to a setting higher than the factory will give better acceleration and response to the throttle.
I run a 383 stroker motor and have a 2400 stall convertor in my tranny, since my Comp Cam is a little agressive. I have set my idle at approximately 900 RPM in neutral and the idle in gear is around 700 RPM. The truck is very driveable and works quite well with these settings.
Frank
Old 09-22-2009, 02:37 PM   #8
Rob73-87
Rob73-87's Avatar
wow - that was lots of information !!
Frank, thank you for your time - I appreciate that very much !!
Well, - you wrote that I should set the timing in "drive" !? I think I heard that before - I`m not sure - okay I will try this (with a buddy stepping on the brakes )!
ANd I will buy a Holley Vaccum gauge - it`s already ordered! Ah, you asked what kind of carb I`m running....it`s a 670cfm Holley Street Avenger (80670 Holley part No).
I`m planning on building a motor similar like yours (383) for my shortbed truck , - but I need to fix my londbed first...
Old 09-22-2009, 05:52 PM   #9
piecesparts
I did not mean to say: to set the timing in DRIVE and I apologize for that---my fingers got ahead of my mind. Just set the idle RPMs in drive so that you get the right setting of around 600 to 700 RPM. Set your timing in PARK, in the shop with the idea of getting the most out of the engine.
Frank
