09-22-2009, 03:11 AM | #1 |
Grill polish
What's the best way to bring a used outter grill back to life? I've tried aluminum polish and stainless polish without getting good results. Am I just not putting in enough elbow grease? What are they made of anyway? Stainless OR aluminum? Also the inner grill; what can I clean those with? Mine's pretty stained from years of neglect.
09-22-2009, 04:47 AM | #2 |
It's all in the timing
Re: Grill polish
Theirs been alot of differant ideas as to what works best,sanding,steel wool,metal polish,and even oven cleaner.I have not got to the grill on mine yet,but if you search this site or checkout the detail section you may find other ideas.
09-22-2009, 07:07 AM | #3 |
Re: Grill polish
the grill is anodized from the factory. to polish the grill the anodizing must first b removed so you can get to the aluminum to polish it
09-22-2009, 02:36 PM | #4 |
Tot Roddin'
Re: Grill polish
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-22-2009, 02:47 PM | #5 |
Re: Grill polish
Mine was so trashed I just painted it the same color as the truck after nudging the dents out of it. Untill I can afford a new stainless one that is! Good luck getting it to polish, I like the mothers aluminium polish...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
09-22-2009, 04:27 PM | #6 |
Re: Grill polish
I did my grill a few weeks ago I tried the oven cleaner thing but it did not work. So I just sanded her down and polished her right up. Take the grill off the truck first.
Here is a photo of my grill now keep in mind it was scratched up pretty bad before. |
09-22-2009, 06:11 PM | #7 |
Re: Grill polish
OK all...............I will just keep on; keepin' on. Thanks for the advice.
09-22-2009, 07:26 PM | #8 |
Re: Grill polish
09-22-2009, 07:31 PM | #9 |
Re: Grill polish
here is a picture of my old 69 grill. i removed the anidized coating then polished on a buffing wheel. good luck with your project. Tony
10-07-2009, 04:35 PM | #10 |
Under Construction
Re: Grill polish
How did you remove the anodizing?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
10-07-2009, 01:25 PM | #11 |
Re: Grill polish
Chada, LMC in Lexena KS has them, they are pretty proud of em tho....
10-07-2009, 03:38 PM | #12 |
Project Junkie! Fishing Poor!!
Re: Grill polish
LMC doesn't have stainless steel grills. They have aluminum, steel, and chrome plated steel. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
10-07-2009, 03:56 PM | #13 |
Re: Grill polish
Mine was in good shape except it was etched by a harsh cleaner by the prior owner. I opted to powder coat it. Supposed to be a "chrome" powdercoat but not bad and certainly better than it was and cheaper than LMC's $660 grille. I paid about $125 and it took 3 days.
10-07-2009, 05:07 PM | #14 |
Re: Grill polish
I used oven cleaner to get the clear anodize off. And get the smelly expensive kind...I tried the "fume-free" and it doesn't work near as good. Soak the grill down good (after removing all the plastic inserts & such) and let it sit till you see the clear bubbling up. Then scrub it good with a brush before rinsing it off. Don't forget to wear rubber gloves & safety glasses while doing this all.
It may take doing this two or three times to get it all off. If the grill is scratched up, sand it till scratches are gone then start increasing the paper grit until it gets smooth. Using aluminum polish is the last step. But if you want a clean, dull, brushed look...finish it off by rubing with a green scotchbrite pad & WD40. This is what worked for me!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
10-07-2009, 05:27 PM | #15 |
Re: Grill polish
www.eastwood.com sales a kit you mix with water and you can strip any of the ole aluminum trim pieces on the truck molding! Afterwards get a buffing wheel and some compound and make it look new again!
Things happen for a reason! |
10-07-2009, 06:35 PM | #16 |
Re: Grill polish
My bad guys they dont have a Stainless grill! On page 71 of my LMC catalog they have the
"paintable" steel black one for 299.95 Chrome Steel one for 399.95 Aluminium one for 299.95 I stand corrected!
10-08-2009, 12:08 AM | #17 |
70 Chevrolet=Obsession
Re: Grill polish
I don't understand why everyone wants to remove the anodizing from their grills. If you do, after a short time the aluminum will dull and you have to keep polishing it over and over again. The anodizing protects the aluminum and keeps it shiny. BTW, those chrome plated steel grills from LMC are only available for 71-72 chevy trucks.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 10-08-2009 at 12:11 AM. |
10-08-2009, 04:08 AM | #18 | |
Re: Grill polish
72 Cheyenne Super 80 Silverado Blazer 2wd |
10-08-2009, 04:43 AM | #19 |
Re: Grill polish
Sounds reasonable.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
10-09-2009, 03:28 PM | #20 |
Re: Grill polish
HI Guys
Just had to say those pictures of your trucks are AWSOME very good looking trucks Take care Jeff Main |
