Radiator hose
I have the 72 with 2in body 454 and aluminum radiator and cant find a decent lower radiator hose for nothing everything either kinks (even with a spring in it) or just dont fit right..a 74 chevy hose bends are perfect but one side is 1.5 the other 1.75 I need 1.75 on both ends..any help?
72 K20 Project now! 70 GMC K20 (Farm truck) on 35's 71 Gmc K20 (Parts truck) 72 Blazer (Parts) 74 3/4 ton (Farm truck) on 35's 84 3/4 ton K5 (Mud toy) on 38.5's 86 3/4 ton (puller) on 36's 98 Cummins (Puller) on 305's |
Between Trucks...
Re: Radiator hose
No insult intended, but have you been trimming the hose to fit? They need to be cut down a little bit.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 09-22-2009 at 09:50 AM. |
more ideas than money
Re: Radiator hose
Have you tried the blue hoses? I cant remember but I think that they are goodyear??? I had a similar problem with my jeep and its lower hose, so I got the blue hose and have had it 2 years so far with no problems. I want to say goodyear gator hoses, but I dont think that is right.
edit* The hose is called high miler. While I was looking for that I found this also. http://www.coolflex.com/cfm/welcome.cfm Sounds like that might help also.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban Last edited by rwolf9653; 09-22-2009 at 10:31 AM. |
Re: Radiator hose
Yes I tried trimming them.. I have a flex hose now that worked great until I started it and it got hot then kinked and bent the spring in it
Too many projects
Re: Radiator hose
If you have a friendly parts store I always go in the back and find what I need. Bring the 74 hose and a tape measure to find one similar with the right ends. Or shove the 1.5 over the 1.75, I've done that in the past.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Active Member
Re: Radiator hose
I ended up buying two different hoses cutting them roughly in the middle(it just happened that way) and using a piece chrome molly tubing inside to make the splice.
I used a Gates shrink to fit hose clamp which formed a nice clean seamless intersection.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() Join Date: Feb 2001
Re: Radiator hose
Good idea...I would not have thought of that.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
"THE GREEN GOBLIN"
Re: Radiator hose
I had the same problem I bought the 75 bigblock lower hose the bends are perfect and I just lubed the hell out of it till I managed to get the other end on. On the other hand this thought came to mind "take the radiator in and get the lower part where the hose goes changed out and rewelded to the right size nothing a good welder couldn't or wouldn't do...
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Re: Radiator hose
Thanks guys I finally got one that works great it was a Kelly Springfield hose PN 0008..
#10 | |
"THE GREEN GOBLIN"
Re: Radiator hose
Thanks Pablo.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 09-24-2009 at 05:18 AM. |
