09-22-2009, 01:39 PM | #1 |
Stock Tire Size
Can someone please tell me the stock tire size is for a 1/2 ton 1970 C-10? I have searched and cannot find it. I have two different size tires on my truck so I am not sure which is correct. Also I was wondering what load factor we should look for when looking for new tires?
Thanks |
09-22-2009, 02:00 PM | #2 |
Re: Stock Tire Size
Usually, they used a 9.5 x 15 (no profile back in the day). In today's standards, it's around a 235/75/15 I believe. Plus, unless you're going 100% stock, just get what fits, looks good and serves your purpose. If you're hauling enough to be concerned about load rating, you probably need a 3/4 ton, seriously. The tires today are pretty tolerant to any load you're going to put in that thing.
If you want to go slightly bigger, you should be able to run a 31 x 10.50 x 15 with little trouble. |
09-22-2009, 02:07 PM | #3 |
Re: Stock Tire Size
Thanks very much.
09-22-2009, 05:17 PM | #4 |
optomistic ah-so
Re: Stock Tire Size
Mine apparently was equipped with L78-15's as delivered, but G's were supposedly the factory spec. The letter is supposed to indicate a load rating, but in order to reach that load rating the tire diameters changed as well. The closest in dimensions to a G78-15 would be the (P or LT)235/75R15 mentioned.
Gear ratios for the speedometer were not all that high of a priority back then, apparently. Coker tires' website is one place where you can find cross-reference charts for some tire sizes...anyone else know a few?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
09-22-2009, 05:44 PM | #5 |
20' Daredevil (Ret)
Re: Stock Tire Size
I've seen others, but dunno where... Google found this:
http://66ford.fordregistries.com/Tir...0Reference.htm
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-23-2009, 12:21 AM | #6 |
70 Chevrolet=Obsession
Re: Stock Tire Size
I believe the most popular load rating for 1/2 tons back in the day was "D."
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
