09-23-2009, 07:38 PM | #1 |
70's 1 ton VS early 90s 1 ton trucks?
As I understand it they kept the square body on the 1 ton trucks until 1991, right? I'm curious what the differences and upgrades might be between the 73-80 style truck and a 1991 model? Did the frame ever change?
I'm starting to restore my '79 1 ton, but I'm thinking I might be better off starting with the newest one I can find. I know people like to swap the early 90s front end onto the older trucks, but I prefer the 73-80 body style. Would it be just as easy to swap an old front end onto the newer truck? |
09-23-2009, 09:45 PM | #2 |
Re: 70's 1 ton VS early 90s 1 ton trucks?
The only big differences(to me) other than obvious body and grille changes in the newer trucks is in 1985 GM started using a hydraulic slave clutch instead of the mechanical linkage used on 1973-1984, and in 1987 TBI(throttle body injection) came out and replaced carburetors. I don't believe the frame itself changed, just different length wheelbases.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 09-23-2009 at 09:46 PM. |
09-23-2009, 10:34 PM | #3 |
Happy to be here
It really depends on what your goals and priorities are. If you can find a clean late model 1 ton you might save a lot of time and money.
You will need the entire front clip, core support, and frame horns to do the 73-80 conversion.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-23-2009 at 10:34 PM. |
09-23-2009, 10:58 PM | #4 |
Older one tons are cooler; but the newer models feature extended cabs..... which are nice for families.
09-23-2009, 11:02 PM | #5 |
While GM continued to make 4 door square body trucks until 91 the 1988 model year was the last year for 2 door square body pickups and this was in 4 wheel drive only.
Here is a pic of my 1988 V30 2 door regular cab pickup built in May 1988. |
09-24-2009, 04:06 AM | #6 |
Ahhh...poop. I was hoping I could find a 2 door 2WD '91 on craigslist. Just hoping for something that hasn't been sitting out in a field for quite as long as mine has. My '79 is still a pretty good starter for a restoration though. I plan on buying a few more old junkers and parting them out to get everything I want...
09-24-2009, 07:53 AM | #7 | |
Dooley - is your truck VIN'd and registered as a 1988 model year vehicle? Does it have 1988 (or 1987) model year literature in the glove box? I thought 1987 was the last model year for 2 door R/V pickups. Everybody - there were no (significant) frame changes between '73 and '91 for the C/K/R/V models, btw. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-24-2009 at 07:56 AM. |
09-25-2009, 01:42 AM | #8 | |
09-25-2009, 07:30 AM | #9 |
Ah - I think it's coming back to me now.
Maybe the breakpoint was not 2 door vs 4 door, but the last 1/2 or 1/2 and 3/4 tons were in '87 and we continued the "heavy duty" R/V trucks into 1988. It's all a bit fuzzy. That was 20 years ago! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-28-2009, 04:03 AM | #10 |
My truck was built in Janesville. Here's a page from 1988 GMC R/V literature. It mentions the V series regular cab and that 4x4 and dual rear wheels were standard.
09-24-2009, 03:38 AM | #11 |
also got the 4l80e on the last year
