Old 09-23-2009, 10:17 PM   #1
clemsparks
Why's my engine so high?
Hi all,
I'm trying to figure out what a prior owner did to make the engine sit to high in my new-to-me project '77 SWB.
Here is an overview where the fan-to-shroud mismatch is a dead giveaway that something is awry:
Looking closer at the engine mounts...everything seems so be more or less in order:
I figure it's possible that this is could be a common malady. For instance, maybe there's a combination of frame/engine mounts that makes this happen.
Has anyone experienced this before or have any ideas?
Thanks,
Clem
clemsparks is offline   Reply With Quote
Old 09-23-2009, 10:21 PM   #2
clemsparks
Re: Why's my engine so high?
And while I'm at it...did GM ever paint a 350 Blue like that or did I just buy a truck with a 305? It doesn't even run as well as a 305 really
(I was told it was a "355"...which I am aware is a .030 over 350)
The real point of the post though is to be able to get the engine set correctly next time one goes in (weather it be this one or the '95 LT1 I have in mind for it )
Clem
Old 09-23-2009, 10:26 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
The riginal motor for 77 would be a 350 that was painted GM blue.
I can't tell what going on wiith your motor because of the angle of the pics. Do you have any others?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-23-2009, 10:37 PM   #4
clemsparks
All I have currently (in addition to the ones above) are these:
(another shot at the Driver Side mount)
A shot at the passenger side mount
A likely unusable shot of the passenger side mount from a wierd, low angle
If you give me an idea what you need to see, I'll get some photos up in the next day or two...
Thanks!
Clem
Old 09-23-2009, 10:40 PM   #5
asphaltburner
asphaltburner's Avatar
Yo! Just checked my '76 Camaro and '78 FRANKENTRUCK and the mounting sure looks identical,...BUT my Camaros' fan shroud seems to extend higher than the one I see in your pics,...in both my Camaro and the truck (truck doesn't have it's installed yet) the shroud would rise about 2" above the radiator top. Center of the fan is at about 7.5" below the top of the radiator, and the top of the shroud is about 9.5" from the fan center.
Hard to tell from the pics if the engine angle is extreme, but that shroud just doesn't look proper.
I'll get a pic and post.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-23-2009, 10:41 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
I can't really tel from the pics but it almost looks as if it has the wrong radiator/fan shroud
Articles-
"Refining Sierra"
Old 09-23-2009, 10:43 PM   #7
clemsparks
Oh!
I forgot I had this one too...
I guess it would make sense if it was just a shroud...
Thanks!
Clem
Old 09-23-2009, 10:46 PM   #8
clemsparks
And yes...that IS a coat hanger holding tension on the steering pump in the last photo. That's the way I got the truck...and the FIRST thing to be fixed (well...after several layers of dirt that got blasted off ).
Clem
Old 09-23-2009, 10:47 PM   #9
AceX
>130dB Moderator
AceX's Avatar
Wrong shroud.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-23-2009, 10:52 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah, thats the one I needed. AceX is correct, that is not the correct fan shroud.
Articles-
"Refining Sierra"
Old 09-23-2009, 10:56 PM   #11
clemsparks
Cool, thanks a lot folks!
I'll add that to the list of things to look out for next time I'm at the yard or parts truck or such...
Clem
Old 09-23-2009, 11:07 PM   #12
asphaltburner
Yo! Here's some pics of the Camaros fan shroud and engine mount:
Name:  092309 001 (Custom).jpg
Name:  092309 003 (Custom).jpg
But the trucks' radiator extends higher:
Name:  092309 005 (Custom).jpg
11" from the top of the rad. to the fan center with a 19.5" diameter fan. Mounts look just like yours and the Camaros'.
Check these measurements with yours,...I still suspect the shroud. Both have 350s.
Todd.
Old 09-24-2009, 02:53 AM   #13
AceX
>130dB Moderator
AceX's Avatar
Here's a bad shot of what th stock shroud should look like. Overal the shroud is very fluid in its transitions. Yours looks like it came from a passenger car and then attacked mercilessly.
Living Life @ 130dB
RIP El Jay
Old 10-12-2009, 07:47 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your shroud is different than his would be. Your truck is later and has the taller radiator than his 77 would have. They changed that it 81 when the front clip changed.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-12-2009, 08:44 AM   #15
donut
donut's Avatar
Looks like the wrong shroud for the fan.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-12-2009, 10:36 PM   #16
bitchin85
bitchin85's Avatar
is that the right fan? it looks like it was replaced. maybe with the wrong one?
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 10-12-2009, 10:38 PM   #17
bitchin85
bitchin85's Avatar
also is it just me or does the motor look like it doesn't sit as level as it should?
Old 09-24-2009, 06:53 AM   #18
D13
D13's Avatar
You've got a V6 shroud that's been cut. They are longer and stick back rearward. Yours has been hacked up. The shroud should be easy to jyard, just watch out for the 6's and diesels, they can be different.
Might also check your trans mount, that will make the motor nose up if it's collapsed or someone had swapped in a wrong crossmemeber.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-28-2009, 01:12 PM   #19
clemsparks
Hey all,
I'm wondering if maybe my truck wasn't an I6 to begin with. Does anyone know an online decoder for my 13 digit VIN (which is ccu147s129903). If someone just wants to decode which engine came in my truck in this thread here...that's fine too. If there's an online one, It'll just be handy for all the other numbers. (I know 129903 is probably the build sequence...I used to work in a GM plant. That number was very important to us)
It's really of no consequence to me which engine it came with...it's just nice to know as I work on the truck (replacing/upgrading parts and such).
Thanks,
Clem
Old 09-28-2009, 02:08 PM   #20
clemsparks
Oh...I was doing some other looking around on the projects section and found the decoder at http://www.73-87chevytrucks.com/VIN.htm
So...my truck came with a 305 (possibly the engine that's in it now...).
I guess I'll have to try to read some casting numbers off the back of the block and see what's in there (I was told it was a rebuilt 350 when I got it...but I have a fair amount of skepticism there...).
That does seem strange that I have a non-V8 fan shroud, though. Does my radiator look right? It doesn't come all the way to the top of the core support.
Thanks,
Clem
Old 09-28-2009, 02:28 PM   #21
Sniper X
First idea I got was that your truck came with a 250 or 262 or 292 straight six and someone did a swap. A very backwoods swap.
Sniper X is offline   Reply With Quote
Old 09-28-2009, 03:06 PM   #22
87Bob
Talking Re: Why's my engine so high?
I'm sorry but I have to ask what was it smoking? I know I'm just being a smart as but you left youself wide open. Glad you get some good answers.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 10-12-2009, 01:54 AM   #23
Captainfab
60-66 Nut
It's a little hard to tell in the pics, but it almost looks like the clamshells are the tall ones, which would make it sit up a little higher. I also noticed that your PS pump brackets are the short water pump style used on the '69-'72 trucks. Just a FYI for you.
Old 10-13-2009, 01:48 PM   #24
clemsparks
On the power steering pump bracket: I've got a long water pump. You're saying I have short pump style bracket? I don't think this is the case becasue it's a big bracket that also has provisions for a smog pump (or something) that wouldn't have ever been on a short water pump engine, as far as I know.
I'd love to get to the bottom of that. can someone post a photo of their long water pump power steering pump bracket? Mine has a cast alunium part (that can't be removed from the pump until the pulley is off) and a stamped steel part. I'll try to get better photos of it now that it's off the truck.
There were "tall" clamshell engine mounts? What were they used for/on? Just curious because my engine does appear to have a downward slope to the rear.
Thanks,
Clem
1989 Shorbed 2WD project
1983 K20 Longbed workhorse
Old 10-13-2009, 07:42 PM   #25
ron350
ron350's Avatar
Clem your motor must have the wrong block to motor mount brackets because the exhaust manifolds are way too high.
The bottom of your exhaust manifolds should be lower than the top of the frame rails.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
