draining coolant
I need to change my block heater on my 2006 5.3L half ton. does anyone know where the radiator drain plug is and also the block drain plugs? ( I can't believe I would ever have to ask such a question) Thanks in advance.
![]() Join Date: Sep 2005
Re: draining coolant
Not realley it will still leave guild in the block bit you have to drain it anyway u willl loose some changing the blocker heater
These trucks do not have a coolant drain. Just remove the lower radiator hose and quick point it into a 5 gallon bucket. That's all you can do.
thanks for the info...... so they don't have block drain plugs either? Seems logical. Thanks again
Wow, that sounds messy...for another $4 or so they could have put a drain plug in the radiator...too bad.
_____________________________________________ 1960 F100 (soon to be SBC/700R4) 2005 GMC Sierra |
