So this is just a little annoying and would love to get rid of it. I have a little squeek in the steering column. It is near the top (steering wheel) and squeeks when I turn. A realize this could be a whole host of things, but I thought I'd just throw it out there to see if anyone else has experienced something similar.
BTW - its a tilt column. Thanks for your thoughts. ![]() ![]() ![]() |
pkbinplano
Pull your steering wheel off, lube everything and then put a custom wheel back on ! Tell your wife your steering wheel went out and you had to get another one.
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
I'm back with 2nd truck!
Sounds like the horn ring maybe be rubbing. Easy fix. For instructions on tearing down and replacing back look here http://home.t-online.de/home/O_Scholz/steering.html
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Workaholic
Mine squeaks too, but hopefully I can fix that when I tighten up the tilt.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
LED King
Mine sweaks bad too. Unfortunately, the screws kept coming out (scary isn't it? Try to turn too fast and.. oops! there goes the steering wheel) so I put some threadlocker in it. I'm just going to live with it for now. {BTW you should hear our 99 Tahoe... it is VERY loud and "farts". We have tried getting the dealership to fix it... several times... but that was a fiasco and a half.}
I had to install the adaptor kit upside down for the wheel to be properly alligned. (when I got the truck the steering wheel was 30 degrees right while the truck was going straight) This is what I think is causing my problem. Check the screws holding the adaptor on & tighten them down. Think about putting threadlocker on them too. It could also be the trim under the adaptor. Make sure it isn't bent or dented.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
