Old 09-29-2009, 09:38 AM   #1
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
fleetside rust protection
got my fleetside bed dismantled, how do you guys get rust converter inside the rear caps on the bedsides? I'm using ospho on all the seams, figuring since its like water-thin it stands the best chance of getting between seams, but getting everywhere inside those end pieces appears impossible. Ditto with the tailgate, actually.
Larry
fleetsidelarry is offline   Reply With Quote
Old 09-29-2009, 01:05 PM   #2
1964C10
1964C10's Avatar
Re: fleetside rust protection
I'd be interested as well. I am doing the phospho as well and used a spray bottle to get most wet on my rear bed pan. The stuff is fairly cheap so I am thinking about putting on some long gloves and just using a sponge to get it in the hard to reach places.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 10-01-2009, 10:28 AM   #3
fleetsidelarry
Senior Car Nut
well, '64', as usual my thread is turning out to be a bust. I'm thinking about buying or making some "daubers" like POR-15 sells. and I did buy some mini-rollers (about 6"x1.25") which fit on 1/4" rod, I'm going to run one thru the rolled part of the front bed panel with some POR or Rust-o-leum. My friend suggested we tape-up the bedside end-panels, pour in some paint and the two of us rotate the bedside around. Maybe it's not a big deal but I hate to have it all apart like this and not do something.
Larry
Old 10-01-2009, 10:23 PM   #4
1964C10
1964C10's Avatar
Larry, I wont be getting to it until next week sometime but I like your idea of just pouring some paint in it, I would probably thin it out a little with lacquer thinner since the paint is pretty thick. How clean were you able to get it? I would imagine if it hasn't rusted in 40+ years it probably wont now hahaha. Keep me posted though!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-02-2009, 07:50 AM   #5
fleetsidelarry
Senior Car Nut
1964C10 asked: How clean were you able to get it?
the insides were surprisingly "clean", looked like "surface rust only" from what I could see, I stuck the sand blaster in every gap and opening there was just to get as much loose stuff out as I could
Larry
Old 10-02-2009, 08:00 AM   #6
fleetsidelarry
Senior Car Nut
finally figured out the multiquote
Originally Posted by brawley View Post
has anyone ever tried 3M 's drip check, or at least thats what I think its called , I heard it worked really well??
Never heard of it, brawley, I'll check out the 3M product list. Do you know how it's applied?
True, I thought that too. Same friend says it will outlast me.
Larry
Old 10-01-2009, 10:44 PM   #7
brawley
Easy Does It
brawley's Avatar
brawley is offline   Reply With Quote
Old 10-02-2009, 09:44 AM   #8
1964C10
1964C10's Avatar
I would agree and as long as its clean of grease and oil etc it should be just fine. I took one of bedsides last year and just washed it down, give it a wipe with some lacquer thinner and then spray painted it to see if I liked the color, well low and behold a year later that paint is stuck on there like I put it on there yesterday.
Btw Larry you knowwwww you gotta post some pictures of that '48 Coupe you have lol
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-02-2009, 08:41 PM   #9
fleetsidelarry
Senior Car Nut
I've been meaning to get the picture-posting firgured out, we'll see. It's a rust bucket like the truck and the panel, but it does kinda look cool, is registered, insured and drives (better now that I got the windshield in)
Larry
Old 10-02-2009, 08:47 PM   #10
protrash64
Resistance is Futile
protrash64's Avatar
Hey guys, I was reading thru this and was wondering what 'phospho' is??? I'm looking to do something similar when I repair some stuff on my 'burb. Talk about hard to reach places..... Something sprayable that is a converter or similar. Thanx
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-03-2009, 07:47 AM   #11
1964C10
1964C10's Avatar
Phospho is short for phosphoric acid which you can buy from like Home Depot. It is the "rust" converting ingredient found in things like rusty metal primer and also in products from like Eastwood and POR15 that "treat" metal. Basically it takes rust or iron oxide and converts it into an iron phosphate. It works awesome! After you treat a part with it it can leave a scaly finish which will actually not rust at all. What I do after I wire wheel a part I wipe it down with phospho and just leave it bare metal and it wont rust. If you do some research you will some people are against it since it etched the metal and are concerned that it will just keep on etching underneath the paint etc etc. I am just adding that as a disclaimer but I haven't had that experience at all. As a matter of fact paint will stick like velcro. What I do is I treat the hard to reach placed with phospho then I rinse it really good and wipe it again with a damp rag with phospo and then primer it.
This is just my experience anyone else feel free to jump and share more. Hope it helps!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-03-2009, 08:13 AM   #12
fleetsidelarry
Senior Car Nut
"Ospho" is the brand name of the product I've been using, as 1964C10 said, you should find it in any hardware store or Home Depot, etc. It's as thin as water and can be sprayed, just remember, it's an acid!
Windshield?? you mean GA bugs between your teeth is not enjoyable! and we don't care if they are rust buckets or not, they are just cool!
Nah, bugs are fine, they're protein (now a bird, esp. one of those big turkey buzzards, would have been a problem), I was having trouble seeing, had to wear goggles, which didn't work well over my bifocals
Larry
Old 10-03-2009, 07:41 AM   #13
1964C10
1964C10's Avatar
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-03-2009, 09:36 PM   #14
1964C10
1964C10's Avatar
Just hosing it down with water will neutralize it, and it also does not do anything to bare metal just to iron oxide or rust. Just dont let it touch concrete it will eat through it like its butter! It is a really weak acid for the rest though, I mean I get it on my hands and it doesn't really feel any different then like lacquer thinner. But gloves would be prudent though!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-04-2009, 08:06 AM   #15
fleetsidelarry
Senior Car Nut
Thanks for the info. I'm not sure if I want to shoot it into blind areas if it has to be neutralized. I have used Duplicolor Rust fix out of a rattle can and it works well, however its expensive for one can and doesnt go very far...we all know there is a lot of area to cover on these old trucks.
don't know if it needs to be neutralized, directions say flush with water when used on galvanized, just let dry and wipe if used on plain steel.
http://www.ospho.com/directions.htm
anybody out there with a negative experience with this sort of rust converter?
Larry
Old 10-04-2009, 11:32 AM   #16
protrash64
protrash64's Avatar
....thanx for the info.
Old 10-05-2009, 06:39 PM   #17
fleetsidelarry
Senior Car Nut
You're welcome, thanks for posting
well I'm tryin, but I can't seem to get my pictures resized down to 100kb, I'm using 'irfanview', what pixel size are you using (I'm at 500x371)?
Larry
Old 10-05-2009, 06:59 PM   #18
1964C10
1964C10's Avatar
I don't resize mine at all, I use photobucket to store my pictures and just post the link here and it shows up in the text. Let me know if you need help getting that up and running. 500X371 isn't very big and details will unfortuantely get lost, remember bigger is better lol
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-05-2009, 09:29 PM   #19
fleetsidelarry
Senior Car Nut
OK, '64, I'm trying it your way:
Larry
Old 10-06-2009, 10:27 AM   #20
1964C10
1964C10's Avatar
Ah man that thing looks awesome!! Are those three Strombergs on there? That thing is gonna look awesome once its driveable! So how do you choose which one you work on lol!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-07-2009, 10:10 AM   #21
fleetsidelarry
Senior Car Nut
Thanks! They're rochesters, it's been a real trip putting the system together, getting it setup and running decent.
It's tough to decide which to work on sometimes but the truck always takes precedent, it's a daily driver (and I love driving it) and there's ALWAYS something to do on it, in addition to the body work.
Larry
Old 10-07-2009, 10:29 AM   #22
1964C10
1964C10's Avatar
I bet they sound great though! I have never done a triple setup like that but I hear it is a real challenge to get them hooked up right.
Btw welcome to the board! Hope you have fun here and feel free to ask tons of questions!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
