09-29-2009, 09:48 PM | #1 |
what carb should i use...
my truck has a rebuilt 355 with mild cam high compression heads and an edelbrock open throat intake with a 3 inth spacer on it. ( my redneck version of A highrise haha) i have a 1406 edelbrock 600cfm on it now and it runs really ritch. the carbs only 2 years old but it sat with gas in it on my project car. i have the air fuel screews turned out 1 1/2 turns and the choke is set right. someone told me it could be gummed up and a float or somethings stuck inside causing it to run rich. i also have a freshly rebuilt 500 cfm edelbrock sittin on my bench. will this be enough for my motor or should i tear my 600 apart and find the problem? thanks
"I'll keep my guns, money, and freedom. You can keep the "change" |
09-29-2009, 10:16 PM | #2 |
Re: what carb should i use...
Maybe float needles sticking? Why not "pop the lid" and see if it's a float issue? Would be easy to correct.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels Who needs a car when they make crew cab trucks? |
09-29-2009, 10:19 PM | #3 |
I would just get it rebuilt.
09-29-2009, 10:25 PM | #4 |
id like to just go buy a new holley fr it but im strapped for cash.. would the 500 kill my motor if i out it on as a quick fix or would i even notice a differance
09-29-2009, 10:39 PM | #5 |
I don't think it would "kill your motor" so to speak. If the carb is in good shape, it should do you just fine. It might run out of breath at high RPM's, but it should be good for driving. I'd put it on there till you can get the 600 fixed. I'd bet that 80% of people who hop up their engines are running over-carbed anyway.
09-29-2009, 10:52 PM | #6 |
i have a heavy foot but im not racing the thing. and itll probly help me at the pump cuz it aint no honda lol thanks guys
