09-30-2009, 07:29 PM | #1 |
HEI Conversion
What terminal on the oem fuse box on my '66, should I connect the 10 gauge HEI power feed wire from the new HEI distributor?
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson |
09-30-2009, 08:00 PM | #2 |
Junior Member
Re: HEI Conversion
I don't remember exactly on mine, but I think they are marked. One of those hanging out on the right side I think is marked IGN, but I am not sure. You could use a volt meter to see which are hot always and which are hot switched.
I took my HEI off and gave it to Tony 'LilRed' some time ago and went to a Pertronix for the small distributor look. I can look at my fuse panel if you need me to.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 09-30-2009 at 08:01 PM. |
09-30-2009, 10:51 PM | #3 |
Re: HEI Conversion
You want an IGN hot source for your HEI power. It's also a good idea to have an inline fuse.
09-30-2009, 10:53 PM | #4 |
Re: HEI Conversion
What size fuse is suggested?
09-30-2009, 11:25 PM | #5 |
Re: HEI Conversion
16ga minimum (no more than 7' if you're hiding the wire routing) w/a 30amp fuse. If the routing exceeds 7', step up to 14ga wire.
09-30-2009, 11:44 PM | #6 |
Member of the longbed union.
Re: HEI Conversion
It should be a red wire, I think a 20 amp fuse is good. but i could be wrong
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
