Old 10-04-2009, 12:24 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Big Block Install Help
I just got a 401 BB and was wondering what mods do I have to do to make it fit and still steer. What steering box and placement on the frame? It's going in a '50 Chevy
Laid_Out_50 is offline   Reply With Quote
Old 10-05-2009, 07:30 AM   #2
63 & 64 Bowties
and a few others
Re: Big Block Install Help
Here's a bump for ya.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-05-2009, 04:07 PM   #3
50adrod
50adrod's Avatar
I have seen it done it will fit, I also had pictures let me see if i still have them
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 10-05-2009, 04:09 PM   #4
MrTucker
MrTucker's Avatar
I believe FrizzleFry has an AD with a 502 or something in it...
MrTucker is offline   Reply With Quote
Old 10-05-2009, 05:43 PM   #5
pgf545
pgf545's Avatar
I am doing one in a 52. I can't really help you much with the stock setup. The one I am doing is a Heidts mustang 2 setup and a *****in Products firewall. I am pretty sure it would work ok with the stock firewall but ours was so trashed that we replaced it. Take a look at my build thread for some pictures. Let me know if you need anything else.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 10-05-2009, 06:45 PM   #6
OrrieG
OrrieG's Avatar
From what I have seen on other builds here if you go with the stock frame big issues are going to be distributor interference (need to notch firewall), header/manifold conflict with stock steering box (box need shifted outboard), header conflicts with upper frame rails (need notched and reinforced) and possibly conflict between fan and radiator. If you are going with a manual transmission clutch linkage or hydralics can get interesting. Other factors will be brake MC and booster location (firewall or underneath). You should do a deep search of the build threads to get more information. then get out the tape measure and start trial fitting the engine to the frame and radiator core support. If you are using aftermarket front end they should be able to tell you what challeges and conflicts there will be using their stuff.
Old 10-05-2009, 08:32 PM   #7
50adrod
50adrod's Avatar
here is one pic of a 502
Old 10-06-2009, 02:47 PM   #8
gab50
I have one in my 50. It was done before I got it but it looks like the firewall stayed stock. It has shorty headers, the rad looks to be moved a small bit forward, it required an electric fan on the forward side of the rad as the water pump pulley is quite close to the rad and it looks like the steering was switched to late 50"s steering box. Job wasn't done very nice and this winter I am switching to late model power steering with the box forward.
gab50 is offline   Reply With Quote
