Old 10-08-2009, 01:05 PM   #1
lil blue
lil blue's Avatar
pic of lifted 67
does anyone have any pics of lifted 67 c10 and what did u lift it with
thanks
lil blue is offline   Reply With Quote
Old 10-08-2009, 07:02 PM   #2
mclairmo
Re: pic of lifted 67
I've asked this here before since I am doing the same to my 68 C10 and nobody here really has done it. I just bought cast aluminum front and rear coil spring spacers off Ebay that should lift it about 2-3 inches all around. I may also fab up some 1.5 inch upper ball joint spacers and mount the ball joints from under the arm instead of on top like oem. That should give me more travel and maybe even more lift up front. I will then buy some one inch aluminum body lift donuts/blocks and lift the body just one inch. May have to extend steering shaft, lower radiator a bit, extend brake lines and elongate bumper bracket holes but should not be too bad since it is only one inch. I have seen others place the rear axle under the control arms, too, but this requires removing the mounts from the axle tubes and rewelding them on top of the tubes, which is not something I really want to do if I can avoid it. I did find a guy online that really lifted a 66 or older C10 by using a 73 and up Fabtech 2wd suspension lift kit but Fabtech discontinued it. Not sure if the even later model 2wd lift kits will work. Have not seen it done yet.
mclairmo is offline   Reply With Quote
Old 10-08-2009, 08:44 PM   #3
Hey now that`s a thought.I`m not sure,but I believe the`88+ f/e assembly will still swap,like the`73+.
Old 10-10-2009, 12:02 PM   #4
lil blue
lil blue's Avatar
i seen one lifted and i asked the guy what he did but he hasnt emailed me back yet ill let u know what he did
Old 10-10-2009, 05:28 PM   #5
OARNGESI
OARNGESI's Avatar
HAVE YOU SEEN THIS THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=365260
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-10-2009, 08:17 PM   #6
lil blue
lil blue's Avatar
im loking for a lifted 2wd
Old 10-10-2009, 08:42 PM   #7
thebrown83
thebrown83's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=352210
thebrown83 is offline   Reply With Quote
