Old 10-11-2009, 08:27 PM   #1
roadking-111
roadking-111's Avatar
rear drum brake question
I'm in the process of rebuilding my rear brakes on my 69 C10. Can this piece be removed by unscrewing the two 3/8 bolts on the back side? One of the bolts is stripped and I can't get it out without drilling. Just need to know if it's necessary. My search is broken, is there any rear drum brake rebuild threads out there?
roadking-111 is offline   Reply With Quote
Old 10-11-2009, 08:38 PM   #2
vectorit
What?
vectorit's Avatar
Re: rear drum brake question
That is your wheel cylinder, and yes the two bolts behind it hold it to the backing plate.
If I were you, I would grind the head off of the stripped out bolt. Then when you get a new wheel cylinder, just buy new bolts to re attach it to the backing plate.
Napa sells those pretty cheap.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-12-2009, 08:24 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Take a hammer and chisel and knock the head off of the stripped bolt. Then the wheel cylinder will come off. The wheel cylinder will cost you 15 bucks or so. A new bolt maybe a quarter.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-12-2009, 08:41 AM   #4
dznucks
dznucks's Avatar
i just replaced mine this weekend. Napa had them for $8 each.
i agree grind the head and get a new bolt.
dznucks is offline   Reply With Quote
