Old 10-15-2009, 06:41 PM   #1
vegaschevy
People who have aluminum radiator w/ electric fans
What have you used? Brands? fitment?
I am looking for a nice aluminum replacement radiator that will provide better cooling while adding electric fans, any links? prices? opinions?
vegaschevy is offline   Reply With Quote
Old 10-15-2009, 07:26 PM   #2
PowerPro
Re: People who have aluminum radiator w/ electric fans
i got a nice 3 core radiator for 180 bucks off ebay... mrradiatorguy or something like that. I searched around for a while, found a package deal with 2 12 inch fans and a temp controller for 65 bucks. It works GREAT!!! I love it. Please also note that it's working great on a big block.
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400
Restoration in progress
07 Yamaha 650 V-Star Custom
83 Honda V-45 Magna
PowerPro is offline   Reply With Quote
Old 10-15-2009, 11:19 PM   #3
big_al_71
big_al_71's Avatar
here is what I have...Griffin aluminum radiator with flexalite...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-30-2009, 09:53 PM   #4
Wildstreak
"something witty here"
Wildstreak's Avatar
big_al_71 thats the perfect setup! I would love the parts numbers on that combo or any info that could point me at them, both rad and fan please
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 10-31-2009, 05:22 PM   #5
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: People who have aluminum radiator w/ electric fans
OK, I like it.
Questions:
What size motor are you running with that radiator? Towing?
2 or 3 row Radiator?
When driving, are you using or NOT using the electric fans to cool?
Would like to hear some results of the uses of these as I am looking to purchase one for my truck.
THX!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 10-31-2009, 06:15 PM   #6
haysonj
haysonj's Avatar
Originally Posted by RPOZ11 View Post
OK, I like it.
Questions:
THX!
I have that same fan setup in mine and it works perfect. One fan comes on at 195 and the second comes on at 200. I tow a 4000 lb boat in 100 degree temps and it has never gone over 210 since I put the aluminum radiator and fans. The motor is a fuel injected 383 T400 with GV OD 410 gears and 35 in tires.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 10-15-2009, 11:35 PM   #7
danman987123
danman987123's Avatar
bought my radiator from entropytec on ebay. great quality. you will never speak to the guy he will never give you his number or anything. only form of communication is through ebay. great guy whoever he is. had both plastic fans broken. he sent me 2 new ones free of charge.
danman987123 is offline   Reply With Quote
Old 10-15-2009, 11:55 PM   #8
PowerPro
here's the radiator i got... he bumped the price, but free shipping now, so it's a wash: fit perfect.
http://cgi.ebay.com/ebaymotors/CHEVR...Q5fAccessories
here's the fan setup. sorry it took so long to find it...
http://cgi.ebay.com/ebaymotors/PROCO...Q5fAccessories
83 Honda V-45 Magna
Old 10-16-2009, 11:36 AM   #9
Alex Hayley
PowerPro, what shroud are you using with the fan? Do you have any pictures of the fan and radiator installed?
Alex Hayley is offline   Reply With Quote
Old 10-16-2009, 12:29 PM   #10
PowerPro
The fans provide their own shroud and all the mounting materials are provided in the kit. If you look over on the far side of the radiator, you can see where i put the thermostat by the radiator inlet. BTW, i highly recommend that you put the fans on BEFORE you install the radiator. It will make the project a million times easier.
If you have further questions, don't hesitate to ask!
83 Honda V-45 Magna
Old 10-16-2009, 12:32 PM   #11
PowerPro
Oh and for those of u who are going to ask, i know that's a wierd radiator hose, but it was orriginally chosen to keep the hose away from the stock mechanical fan and it works well at the moment, so i haven't swapped it out. The truck is definitely a work in progress, but the wife wants me to keep it in running condition while i work on it, so... there's only so much i can do under the hood... She's supportive of me having the truck and working on it, so I'm not going to complain about the conditions...
The taped up fittings are for a trans cooler, but i already have one set up. Eventually, i'll be using those ports for an oil cooler. The tape is just to keep out dirt in the meantime.
83 Honda V-45 Magna
Old 10-16-2009, 05:44 PM   #12
mclairmo
I would recommend buying electric fans that include a shroud that covers the entire radiator core like the one big_al_71 has or the entropy units or the ones that WES at Classic Heartbeat sells. Otherwise, you are wasting core area and may experience reduced cooling efficiency. It happened to me and I built a larger custom shroud to cure my heating issues.
mclairmo is offline   Reply With Quote
Old 10-16-2009, 05:58 PM   #13
PowerPro
The same amount of air is going to flow through the fan whether you put a big shroud around it or not. Putting a big shroud around the fan will only reduce the velocity of the air flowing through the radiator (same amount of air, bigger space). The faster the air flows through, the better the cooling. It's all going to mix in the tank on the other side of the radiator anyway, so the TWO tubes that aren't getting air flow aren't really an issue... The main thing u need to look for is high CFM fans.
83 Honda V-45 Magna
Old 10-17-2009, 09:04 PM   #14
mclairmo
Only true when the vehicle is in motion. My comment applies when vehicle is stopped. When the vehicle is stopped the only air going through the core is what the fan pulls through it and any area of the core not covered by the shroud will not have air flowing through it. It is possible to experience increased temps when stopped. Why is it that all oem applications include a shroud that covers the entire core area? I speak from experience. I had both configurations and the larger shroud cured my overheating problem when the vehicle was not moving.
Old 10-16-2009, 06:03 PM   #15
cparman
sharp as a marble
X2 You might also research some kind of control module to start the fans. When dual fans come on it is a pretty good shock to the electrical system powering them. I am aware of two modules that will " SOFT START " the fans. Meaning that when they are told to turn on, the module will ramp up the voltage gently , so as not to create a big load all at once to the wiring
Spal- Usa
Ron Francis wire works
cparman is offline   Reply With Quote
Old 10-16-2009, 06:07 PM   #16
PowerPro
Spal- Usa
The module that came with this fan turns one on then the other... is that what you're talkin about?
83 Honda V-45 Magna
Old 10-31-2009, 12:15 PM   #17
Wildstreak
Wildstreak's Avatar
I was just wondering if it was a kit or just something you threw together.....the flex a lite fan is what Im not to sure of, it looks like you got a kit that works perfect.....
57 chevy 4x4
68 burb 2wd:
Old 10-31-2009, 06:30 PM   #18
Wildstreak
Wildstreak's Avatar
Im really curious to what exact fan from flex a lite that is, they have like 3 or 4 different models of dual fans, and it looks like the fan was meant for the rad the way is attached with the brackets. haysonj Do you have the same brackets on your fan??
57 chevy 4x4
68 burb 2wd:
Old 10-31-2009, 06:43 PM   #19
haysonj
haysonj's Avatar
The fan is the universal one at Jegs It is 27X17 with 13 inch fans. I made my own brackets as the brackets it came with I didn't like.
Old 10-31-2009, 08:05 PM   #20
Wildstreak
Wildstreak's Avatar
I was thinking this one http://www.flex-a-lite.com/auto/html/universal.html or this one http://www.flex-a-lite.com/auto/html...-electric.html with this rad http://www.summitracing.com/parts/GR...X/?image=large
57 chevy 4x4
68 burb 2wd:
Old 10-31-2009, 08:19 PM   #21
haysonj
haysonj's Avatar
The second one is the one I have with the same radiator you are looking at.
Old 10-31-2009, 09:50 PM   #22
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Originally Posted by haysonj View Post
the second one is the one i have with the same radiator you are looking at.
i have the same fans
1971 GMC SHORTY is offline   Reply With Quote
Old 10-31-2009, 08:34 PM   #23
Wildstreak
Wildstreak's Avatar
sweet! was the bracket big_al using the one that you didnt like? Im glad to see yours as well considering I am using it in a 4x4 too.
57 chevy 4x4
68 burb 2wd:
Old 10-31-2009, 09:43 PM   #24
1971 GMC SHORTY
Just got the be cool from jegs today 312.00 with free rad cap. Already had the fans. This rad looks good will take pic tomarrow
Old 10-31-2009, 10:36 PM   #25
vegaschevy
woah! 312? What part number is on your invoice?
