Timing question I think ?
When I turn my truck off it tries to start back up. Is this a timming problem or something else?
Plays with trucks
Re: Timming question I think ?
Sounds like your timing is too far advanced. Did it just start doing this or has it been going on for a while?
Gary My Dad's Old Truck 1985 ![]() |
Same thing happened to me, my started soleniod stuck. Wouldn't stop cranking until the battery died. If it is continuously trying to start itself until the battery dies, I would say its the same prob I had. If it cranks once then dies or twice I would agree about the timing issue.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
Sounds to me like yer describing a situation like after you have driven for awhile then you pull up in yer driveway and shut the key off but the motor continues to run but like crap for a lil while..If that is what is happening it is called "dieseling" or engine run on..many different reasons for run on..I would check all the basics first..timing, idle, airfuel, carburetor adjustments(throttle linkage closing all the way) etc....Then check cap, rotor, wires, plugs and replace as necessary..Basically a tune up if needed..Afetr all the checking you will prolly find the culprit.
Re: Timing question I think ?
Cowboy's the man
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Are you meaning to say that when you shut your truck off it seem to continue to run? If so you need to check your timing. It's too far advanced like 85GMCGuy said. If you are saying that when you turn your key to the off position the starter engages then you have an ignition switch problem my friend.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
When i turn it off it continues to run. I thought it was the timming, i will back it off a little thanks for the help.
