Old 10-15-2009, 08:40 PM   #1
mailman
mailman's Avatar
Bagged with frame mounted gas tank ?
Any one running a frame mounted gas tank with bags?i am debating going back with a in cab tank because i want my air tank manifold and compressor hidden.any suggestions?
mailman is offline   Reply With Quote
Old 10-16-2009, 12:02 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: Bagged with frame mounted gas tank ?
I am in process of building this set up. Not far enough long to tell how it is going to work out though. I plan to mount my air tank pumps etc along the outside of the passenger frame rail.
Oh mine is a long bed so that gives me more room in that area over the short bed trucks. Probably impossible to make work on step beds!
westofb is offline   Reply With Quote
Old 10-16-2009, 01:51 AM   #3
nastyc10
nastyc10's Avatar
I'm running a frame mounted tank under the back of the bed. My manifold valves and compressor are mounted on the outside of the framerails in front of the rear tires for easy access. My tank is mounted in the bed for now but I'm planning on moving it below also.
nastyc10 is offline   Reply With Quote
Old 10-16-2009, 03:39 PM   #4
rickygee
rickygee's Avatar
http://67-72chevytrucks.com/vboard/s...=1#post3567148
see pics.
I am running the manifold under the cab out side of the rail on the passenger side.
rickygee is offline   Reply With Quote
Old 10-16-2009, 04:09 PM   #5
70onB.A.D.'s
70onB.A.D.'s's Avatar
I am running mine on the rear frame rails. air tank is in front of it and and compressor is mounted on the side of the rear rails as well
70onB.A.D.'s is offline   Reply With Quote
Old 10-16-2009, 07:28 PM   #6
mailman
mailman's Avatar
Thanks for the info guys,I think I can put my air tank behind the gas tank without any mods and mount the compressor and manifold on the rear side rails.
