10-16-2009, 12:18 PM | #1 |
bags or static? what would you do?
i almost have everything to bag the front of my 59 apache, i have mixed thoughts about it though. ive built many bagged trucks and have had many super low static drops. only reason i want to bag the truck is its easy to get on to my car hauler and if i have to crawl under the truck i can raise it up and it will be easier for jayme to drive it. i dont care about dragging or non of that stuff. i really like super low static drops, ive had plenty of them and i have it down to a science on how to make them ride good. the rear will be about 9in of drop.
im not worried about blowing bags,burning up compressors or sticking valves. i still have a set of firestone 2800 that are over 10years old lol and it will be a simple two valve, 5gal tank with a viair 380. and if your woundering the front clip under my 59 is from mid 80s c10. what would you do? |
10-16-2009, 01:04 PM | #2 |
Re: bags or static? what would you do?
Personally id go with the static drop, ive never had a bag setup but I like that there is nothin to worry about with a static drop just hop in and drive it no waiting on tanks to fill up or worrying about watter in the lines. But i do know its hard to put a low static droped vehicle on a trailer or get into steep driveways and such.
10-16-2009, 03:40 PM | #3 | |
Air allows easier access for the bottom side of the vehicle for repairs & maint. You have to be creative getting a floor-jack under a 'big' static dropped truck. Sometimes that's easy, sometimes not so easy....
10-16-2009, 04:38 PM | #4 | |
i tons of SS tubing and SS fittings, only thing i need is valves and a compressor. im thinking about going old school with manual valves. |
10-16-2009, 04:45 PM | #5 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-16-2009 at 04:46 PM. |
10-16-2009, 04:58 PM | #6 |
haha yeap, i tore up a nice set of chisholm suspension lower control arms when i had a blow out, drug the bottom almost off. had to jack the rear of the truck up to get a jack under the frame rail then put a jack under the front cross member, and to make it worse it was a hot texas summer day on the side of I20.
10-16-2009, 01:34 PM | #7 |
bag it and dont worry about it, put in some snubbers that will not let it bottom out if you blow a bag or something like that...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
10-16-2009, 02:02 PM | #8 |
Tot Roddin'
If you've got the items needed to bag, this should be a no brainer.
Bag that sucker!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-16-2009, 02:46 PM | #9 |
I bagged my 56 because when it is done I didn't want to hear myself say I wish I would have done that+ it looks so bad laying rocker
10-16-2009, 05:00 PM | #10 |
low n' slo
def bag it...the hardest part is over (getting the parts!). i u sed to drive a 2000 s10 that was static dropped 5 in the front and 6 in the back. I loved that little truck but it was a pita to drive everywhere, I always told myself I should have just bagged it!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-16-2009, 05:07 PM | #11 |
if i bag the front i guess i will go ahead and bag the rear also, dang snowball effect lol. the hardest part for me is motivation...
10-16-2009, 05:37 PM | #12 |
^ yeap ^
10-16-2009, 06:22 PM | #13 |
Happy to be here
If you had never owned a bagged truck, I might say go static and be done.
Since you already know the advantages of adjustable suspension, it's just a matter of time. Bag it now, or bag it later, but you know your going to do it.
10-16-2009, 06:31 PM | #14 | |
so far i have... tank SS fittings SS tubing bags valves i still need... comprssor plates/cups for the front spindles(opional) if i do the rear,i will need... bags metal bushings having the know how and doing the work myself will save me alot of money. i guess im goin to order some parts now... Last edited by fiddy9apache; 10-16-2009 at 06:32 PM. |
10-16-2009, 09:56 PM | #15 |
If its a play truck then bag the SHI outta it! On a DD i'd go static although I know people do drive bagged DD's...just not my preference, my 05 has a static 4/6.
10-16-2009, 10:03 PM | #16 |
its just a toy, im not scared to DD a bagged truck. i did it for years. i think im just goin to bag it just so my old lady wont complain when she drives it. she hated it when she drove my other trucks that would get hung up on speed bumps lol
10-16-2009, 10:08 PM | #17 |
low n' slo
lol I remember those days. it was embarassing! I got stuck in a driveway once and it scared the **** out of me...
u got any pics of the truck ur gonna bag?
10-16-2009, 10:14 PM | #18 |
10-16-2009, 10:24 PM | #19 |
low n' slo
ya...def lay that out. nice truck
10-17-2009, 02:19 AM | #20 |
nice ride! I'd bag it too.
10-21-2009, 01:29 AM | #21 |
I have owned my share of lowered cars and trucks i made a set of small ramps just to get a floor jack under them.I had bags on my 65 impala it was great rode really smooth and i had a toy to play with in parking lots.
10-21-2009, 08:39 PM | #22 |
86 C10
If you lower it your going to want to go lower so just bag it and be done with it!!! Plus if you do right you will have no problems.My truck has been bagged for like 5 years and dd and has never had problem until the head gasket blew!!!
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
10-21-2009, 10:58 PM | #23 |
thats what im thinking, and everything i build it done right. i have no worries really. im pretty sure im going to bag it. ive been running a set of bags on my 92 chevy from 99. besides i still have to wire it for EFI first before i start on the suspension again.
10-22-2009, 06:34 PM | #24 |
Glad i clicked on this thread cause i'm having the same thoughts.Which one will handel better cause i want my truck to handel and look sick sitting low.
10-22-2009, 07:33 PM | #25 |
i believe N2TRX has a 3/4ton sway bar on his bagged truck, i bet it handles pretty good. im going to put the same sway bar on my truck even if i dont bag it.
