10-20-2009, 06:12 AM | #1 |
700 R4 help
Looking for help.
Planning on installing a 700 R4 in my '61 GMC to a 283. I have found one from a 1994 Chevy truck with 60,000 miles on it. Owner says it is not electrinic, has the kick down cable, and was working fine whwn removed. He wants $400.00 for it. Is this the correct transmission to install and do you think the price is good? Thanks Peter |
10-20-2009, 09:53 AM | #2 |
Re: 700 R4 help
Must not be a 94 model transmission then. Last of the true 700R4 was about 91 or 92 then the 4L60E took over by 92-93.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
10-20-2009, 11:14 AM | #3 |
Re: 700 R4 help
ask him for the serial # on the side of the case above the pan and I can decifer it for you if it is in my book.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-20-2009, 03:41 PM | #4 |
Re: 700 R4 help
HotrodYJ's right on the years - I believe you can swap speedo cable driver to the older gear; TV cable setup is tricky on the manifold if you don't have original pieces for your carb - I had to buy a custom cable setup for Holley 4-barrel, which is pricey. You'll also need to move the frame crossmember if you have one for automatic and shorten or replace driveshaft (700r4 is longer); auto shifter/linkage may also be an issue depending on what you have now
10-20-2009, 08:44 PM | #5 |
Re: 700 R4 help
Bowtie Overdrives has a nice TV cable set up for just about any carb set up you can think of. Don't know about the trucks, but cars started running electric speedos in 86.
