10-22-2009, 07:15 PM | #1 |
engine question about my 86 c10
why is it that i cannot find a crate engine listed for my 1986 c10 305 carbureted engine? all i can find listed is up to an 85 and then from 87 on up, everywhere i have checked bypasses the 86 model year. my stock engine has just about had it and i was trying to figure out which way to go. thanks for all of your help.
10-22-2009, 07:36 PM | #2 |
Re: engine question about my 86 c10
85 would be the same as your 86
10-22-2009, 07:49 PM | #3 |
any reason you want a crate engine? why not have a local rebuilder rebuild a 350 and replace the 305.
10-22-2009, 08:23 PM | #4 |
go with a 5.3 or 6.0
you will be happy!
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
11-03-2009, 07:30 AM | #5 |
Get a Goodrench 350 from Chevy they are cheap and a decent motor.
11-03-2009, 10:46 AM | #6 |
I would go with this one
https://store.gmperformanceparts.com...-12499529--%3E it's the "replace all" engine from GM. There is also a 260h.p. version in the GM performance parts catalog. It has a roller cam, and replaces 70-85 engines. The part# for that engine is 10067353. |
11-03-2009, 12:22 PM | #7 |
The reason you are having trouble with a direct application is the '86 was the first year of the 1 piece rear main and the last year the intake bolts were all at the same angle. The The 2 piece rear main seal used through '85 uses a different oil pan and flex plate then the 1 piece. The '87 up will either need an intake for the '87 and newer heads or sloting of the center two bolt holes on each side of an old style intake. Any small block will work, you just need to have the correct parts.
I can still count my vehicles on two... wait three hands. Last edited by Damien; 11-03-2009 at 12:24 PM. Reason: Clairification |
