10-22-2009, 07:24 PM | #1 |
Oil Leak on New crate motor
I have a new GM 350 crate motor with around 120 miles on it that has developed an oil leak. I can't seem to find where it is coming from but it drips from both starter bolts. It seems to be getting worse and now leaves a 2 inch circle of oil on the garage floor after parking it. I looked around underneath and up top but everything looks clean and good. Anyone else have a leak like this?
10-22-2009, 07:26 PM | #2 |
Re: Oil Leak on New crate motor
check the valve cover on the passenger side....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-22-2009, 07:39 PM | #3 |
Grandpa in the rustmobile...
why so specific big al? (JW)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-22-2009, 07:55 PM | #4 |
Active Member
Could be cause that's where it's leaking?
Some times oil migrates so be sure and also check the intake manifold gasket and/or bolt for tightness. I had an engine that leaked in the back seal and migrated on down. I thought it was rear main seal. Wash the engine off real good, run it, wait till it cools off to the touch and then use a white cloth and wipe around the back sides, etc. You will find it. |
10-22-2009, 09:12 PM | #5 |
based on the oil being around the starter bolts, I have been bitten by that dog before....I just read you cjecked and there was a leak out of the back of your valve covers.. I always use fel-pro gaskets on all my engine builts....
10-22-2009, 07:41 PM | #6 |
I just had the same problem with the truck I just bought with a 350 crate motor in it and it ended up being the hole just above the starter solenoid that was intended to be used for a dipstick tube didn't have anything in it. No tube or plug so it was open to the oil pan and any time the engine was running oil would splash out in fine dropplets. I had to look between the header tubes, just to the rear and above the starter solenoid to see it. Might want to check it out. Symptoms were oil burning off the header tubes and a good puddle of oil on the ground, running off the bottom of the starter.
10-22-2009, 08:09 PM | #7 | |
Spanked once
The ole 350 budget build. |
09-06-2010, 11:42 PM | #8 | |
09-07-2010, 01:29 AM | #9 |
Gone to greener pastures
Well (& I'm not being a smart azz here), if worse comes to worse, install another dipstick tube & dipstick.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
08-12-2013, 08:39 PM | #10 | |
Posted via Mobile Device |
10-22-2009, 08:30 PM | #11 |
sharp as a marble
two good suggestions here. Big Al is working on the theory of gravity I LIKE IT. A PACK is working on experience. What side is the oil dipstick on? I read where the 290 hp crate comes with either left or right dipstick provision, this would support A PACK. Might suggest letting the engine get cool, and run your finger around the rear of the right hand valve cover to see if it is wet with oil. If it is dry, look to see if the R.H. dipstick hole is open.
I just installed a 330 hp crate in my Blazer, and I too had an oil leak. It was the timing cover seal. After I got over being PO'd, looked carefully, and made sure that it was in fact the seal. Pulled the balancer, and looked again, to find the darn seal was leaking from around the outside of the seal. I just knew I cut the seal when I installed the balancer. I did use a install tool for the balancer, but just KNEW it had to be my fault. |
10-22-2009, 08:50 PM | #12 |
I just checked and it looks like both valve covers are leaking in the back..I bought these rubber gaskets from summit:
http://www.summitracing.com/parts/FEL-VS12869T/# They are the rubber ones and if I recall they wanted them torqued down pretty good. Any idea how tight they really should be? |
10-22-2009, 09:01 PM | #13 |
sharp as a marble
is it a center bolt style VC? I used Felpro gaskets on mine, and had to stretch them a bit by hand to get them to relax enough to get in place. I did install them dry, no sealers
10-22-2009, 09:17 PM | #14 | |
10-22-2009, 09:20 PM | #15 |
10-22-2009, 09:19 PM | #16 |
45 inch pounds
10-23-2009, 01:28 AM | #17 |
Also make sure your valve cover rails are not bent where the bolts go through if using stamped steel covers. I switched to cast aluminum valve covers to give me a better, thicker and more rigid sealing surface so I can torque them down more than factory specs.
10-23-2009, 09:31 AM | #18 |
72 C30 Trailer Queen
Dont forget to look at the distributor gasket... I learned this one the hard way!
It is just a paper type gasket that seals the distributor body to the intake manifold.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
10-23-2009, 09:54 AM | #19 |
check oilpan gasket// especially if you didnt use a one piece premium one//dont overlook the drainplug either
10-23-2009, 10:07 AM | #20 |
Active Member
Re: valve covers.. After 40 yrs more than likely they have been torqued and retorqued a few times. I always lay the cover on a flat surface to insure they are completely straight. I use a section of flat iron that fits in the outer ridge and tap any high/low points with a body hammer or similar.
I also like Felpro gaskets. I don't like the rubber types even though I have used them before. I guess it's a preference but I've had better luck with Felpro cork/rubber combo. I torque by feel when I see just a slight expanding of the gasket under the bolt I stop. I use a small amount of gasket goo on the valve cover and I replace them as soon as I notice oil seeping out from them -usually 3-5 yrs depending on engine and usage. Most of the time when that happens it's time to replace. |
06-03-2010, 10:08 PM | #21 |
My GM 350 Crate is doing the exact same thing. Gonna check all of these ideas. Thanks for the tips!
06-04-2010, 12:16 AM | #22 |
I use only felpro cork gaskets on my valve covers.I use 3m weather strip adhesive and glue the gaskets to the valve covers first. After they dry sitting on a flat surface I run a very thin bead of blue permatex on the engine side and rub out flat before installing.As long as you do not over tighten and pinch the gasket you can remove and it will pop right off without breaking to adjust valves etc.lightly rub off permatex and run new bead and reinstall.keeps a good seal and makes the gasket reusable.Most valve covers leak due to over tightening or cheap chrome covers .
06-04-2010, 01:17 AM | #23 |
The first time I replace valve cover gaskets I throw away the bolts (not on center bolts valve covers), and put studs in the heads.
Then I put the new gaskets over the studs, to hold them (the gaskets) in place, and then install the valve covers.
06-04-2010, 09:16 AM | #24 | |
Junior Member
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-04-2010, 11:07 AM | #25 |
I had the same issue with oil on the starter. The leak turned out to be a small, almost unnoticeable leak around the PCV valve. The vacuum hose was too long and putting stress on the valve causing it to be slightly cocked in the gasket allowing oil to seep threw. It was a very small amount but built up down below over a short period of time.
