Old 10-24-2009, 01:17 AM   #1
cstm68
cstm68's Avatar
just my luck...
a few monthes ago i was driving my 68 and the right lower ball joint broke, this was just a few weeks after i rebuilt and converted the front to disc. it was a faulty ball joint and i was able to get a new one free,
after this happened the right front sat up about 2 inches more than the left. I aligned it about 3 times at work but fianly gave up. Today i removed the front clip to start shaving the fire wall and i noticed that the lower control arms looked differtent from the top.
i turns out that when the ball joint broke and the arm hit the ground i bent LCA but i could not see the bend from under the truck.
im glad i found this before i started installing my air ride.
so now i need to search for a good used right lower control arm.
are the re pro control arms any good?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 10-24-2009, 09:29 AM   #2
71tahoe
71tahoe's Avatar
Re: just my luck...
If it was a new ball joint, I would see if the place you bought it carries lower control arms. It may be a special order but I think they owe you another freebie.
I have an extra set minus the driver's uppers but I need to hang on to them until I'm finished with my build. Do a search in the parts forum and you'll likely find someone close to you parting a truck.
71tahoe is offline   Reply With Quote
