Old 10-25-2009, 08:11 PM   #1
chris91
driveshaft 1964 longbed
I put a 350 automatic in my truck now I need the driveshaft. When I bought the truck it did not come with one. Will a stock front section of the drive shaft fit without being modified?
chris91 is offline   Reply With Quote
Old 10-25-2009, 08:55 PM   #2
Woogeroo
Re: driveshaft 1964 longbed
what did it have in it originally? a 3 speed manual?
-W
Woogeroo is offline   Reply With Quote
Old 10-25-2009, 10:08 PM   #3
LILRED66
LILRED66's Avatar
You need the slip yoke for the 350, so it will mate with the tranny. You will need to have a drive shaft made or an original one modified.
LILRED66 is offline   Reply With Quote
Old 10-26-2009, 01:09 AM   #4
Captainfab
60-66 Nut
Just get an original 2pc driveshaft and a slip yoke and get the front shaft shortened. It really doesn't cost that much to get a driveshaft shortened. It's when you need a longer one is when it starts to get spendy.
Old 10-26-2009, 09:59 AM   #5
LILRED66
LILRED66's Avatar
My experience has been, they will shorten them, but they will not lengthen them. I ran into this issue recently, while doing a 3-speed Turbo Hydra Matic swap for a forum member. We went from a two piece to a one piece and went ahead and had a new one piece drive shaft made. It wasn't that much more to have a new one made, compared to, shortening the original front piece, welding on the slip yoke and balancing the assembly, so we went with a new one piece with new "U" joints.
Old 10-26-2009, 11:43 AM   #6
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Man if you lived in Tx I would sell you mine. I have a SD crossmember and need a longer driveshaft now.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-26-2009, 12:11 PM   #7
chris91
It was a 3-speed originally. If I were to do the 1-piece the drive shaft would b3 80" long. What is the max length to be be safe? my truck is a longbed.
Old 10-27-2009, 07:02 PM   #8
chris91
My original problem was I did not have the bracket for the carrier bearing to bolt to. After digging off the undercoating off the crossmember I found that someone has taken the bracket. Can I make a bracket?
Old 10-28-2009, 12:06 AM   #9
Captainfab
60-66 Nut
I suppose that would depend on your metal skills. It shouldn't be much of a problem to make. Are you wanting to use the heavier duty one that bolts on the bottom, or the whimpy one that hangs from the top?
Old 10-28-2009, 05:40 PM   #10
chris91
The Original bolted from the bottom. I would like to keep it that way.
Old 10-28-2009, 11:51 PM   #11
Captainfab
60-66 Nut
That's good, that one is a much better carrier bearing. I happen to have one of those mounting plates that I took off of a truck a month or so ago. Let me know if you're interested.
Old 10-29-2009, 12:53 AM   #12
1964C10
1964C10's Avatar
Might you have two of those plates? Mine has the whimpy top mount one.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 10-29-2009, 01:01 AM   #13
Captainfab
60-66 Nut
Wow you've got something crazy going on there. That is the heavier carrier bearing, that someone cobbed a mount for it to hang from the top. Plus it should be on the other side of the crossmember. You'll have to do some changing of the driveshafts to make the original setup work. I'll look and see if I have another one of those mounting plates.
Old 10-29-2009, 10:42 AM   #14
1964C10
1964C10's Avatar
I knew I wasn't going crazy!! When I looked at that setup I was like what the heck is that! The PO also did a butcher job on the 3 speed transmission that is coming through the floor and the steering column is made for either auto or 3 speed I can't(dont know) how to tell. I also don't think there are bolt holes for the heaver carrier in the bottom of the cross member. I am not planning on doing anything to this till I get a new setup for my drivetrain with an automatic transmission but I am collecting parts for now so do you think I might be able to use the carrier bearing that I have? or are parts of it missing? Thanks John!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-30-2009, 12:21 AM   #15
Captainfab
60-66 Nut
It's kind of hard having not seen the top side (bottom as seen in the pic), but what little I can see, looks to be all there. When you buy a replacement carrier bearing, it can be bought as an assembly which includes the rubber and the outer metal housing. I can fix you up with the base plate for it if you like.
Old 10-29-2009, 06:05 PM   #16
chris91
Yes, I am interested.
Old 10-30-2009, 12:18 PM   #17
1964C10
1964C10's Avatar
Thanks John, I will take you up on that offer when the time comes to do my drivetrain. I might end up doing a wider driveshaft as this one I feel is not enough to handle the 400HP I plan to throw at it one day.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 10-31-2009, 01:19 AM   #18
Captainfab
60-66 Nut
I would not hesitate to use the size of driveshaft you have for 400HP. Especially if you stay with a 2pc in your longbed. Let me know when you're ready.
