Old 10-27-2009, 08:08 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
One piece drive shaft runners
Now that Shane has hooked me up with the shims.....What are your pinion angles on the rear end and trans?????
I think any adjustments I do will help, but never hurts to ask. (Unless I ask the wife for time to work on the trucks, thats another story)
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-31-2009, 10:06 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: One piece drive shaft runners
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-31-2009, 12:02 PM   #3
71meangreenc10
My thoughts exactly.....
Someone has to be running a good one piece shaft,,,,,,,would love to know the pinion angle......
Smitty
71 C30 Wrecker
Old 10-31-2009, 03:29 PM   #4
LONGHAIR
I'm not totally sure what you are asking?
Is this an extremely lowered truck? Something that makes you think you ned to adjust the angle away from stock?
"Ideally" the front and rear should be as close to equal as possible, but it's not necessarily easy to achieve.
In stock form the pinion is tilted up a few degrees and the transmission is tilted down an equal amount, so the angles are matched. Lowering with a trailing arm suspension affects the pinion but not the transmission, so "in theory" the pinion needs to be shimmed upward...how much would depend upon a few things. How much drop, LWB or SWB, etc.
A problem comes in with shimming though. Tipping the pinion upward affects both angles.....so you have reduced the actual angle of both but done nothing to equalize them to each other.
How's that for a long-winded answer for a question I didn't understand?...LOL
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-31-2009, 06:12 PM   #5
71meangreenc10
this is what i got.....
When i did my frame off and put it all back together with oe parts, I had a 1 piece shaft that worked fine, after re-assembly with new springs the pinion angle is too far up and about 60 mph it will shake you out of the truck.
the shaft is fine, u joints fine, I want to shim it from the rear thus pushing the pinion angle down.
i would like to know who is using a 1 piece shaft and if they have the ability to measure the angles so I can test mine.
This truck came with a 2 piece shaft originally.
Smitty
71 C30 Wrecker
Old 11-01-2009, 12:07 AM   #6
SCOTI
SCOTI's Avatar
How is it lowered?
How much is it lowered?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-01-2009, 12:09 PM   #7
71meangreenc10
Its stock ride height, no suspension mods have been done.
If I put the shims in the rear of the axle perchs it will push the angle down.
Smitty
Read this post to envision the shims.....
http://67-72chevytrucks.com/vboard/s...d.php?t=369008
71 C30 Wrecker
Old 11-01-2009, 01:17 PM   #8
SCOTI
SCOTI's Avatar
I don't understand why your stock height truck would require pinion shims unless something was changed. The difference between 1pc & 2pc shafts shouldn't impact pinion angle. Is it possible the vibration is from the driveshaft itself since longer d.shafts want to flex in the center of the shaft when they exceed a given dimension?
The pinion on the rear should be 'in phase' w/the end of the drivetrain (tranny tailshaft). Everyone's truck will possibly be different so it's best to crawl under your truck & measure w/an angle finder type gauge available from your local Lowes, HomeDepot, or Sears.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-01-2009, 07:42 PM   #9
LONGHAIR
This sounds like a driveshaft problem not a pinion angle problem. The shaft is bent, out of balance, out of phase.....something.
Old 11-17-2009, 04:57 PM   #10
effects66
effects66's Avatar
This company
http://www.stockcarproducts.com/trkarm1.htm
doesn't make those shims any more. Any one know of another place to get them. I know CPP has them but they are $69 for a pair.
effects66 is offline   Reply With Quote
Old 11-18-2009, 10:26 PM   #11
71meangreenc10
CPP = $$69, figures, how can they explain that cost? Are they 24K gold plated, no matter, they wont get my money....
Smitty
71 C30 Wrecker
Old 11-18-2009, 11:25 PM   #12
effects66
effects66's Avatar
Yeah just rediculous. It sucks that Stock car parts isn't making them them any more.
Old 11-20-2009, 11:51 PM   #13
Hart_Rod
Hart_Rod's Avatar
Smitty
Smitty - here's a good article on pinion angles:
http://www.carcraft.com/howto/91758/index.html
Hart_Rod is offline   Reply With Quote
