10-27-2009, 09:47 PM | #1 |
Blazer frame for truck???
i couldnt really find any info searching for this, so ok this guy i know says he has a 4x4 72 blazer frame and he want to sell it minus the engine and trans for fairly cheap for a 4x4. any way can i make a pickup out of it? and or how much fab would be needed? also is there anyway i can tell its for sure a 72 blazer frame? thanks a bunch
10-27-2009, 09:57 PM | #2 |
Re: Blazer frame for turck???
oops TRUCK !
10-27-2009, 10:47 PM | #3 |
A guy i know put a truck out of a Blazer frame by cutting down the bed. i dnt know any technical stuff or how hard it was but i do know that i can be done and looks sweet!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
10-28-2009, 07:30 AM | #4 |
Re: Blazer frame for truck???
well he was wanting to trade some parts for this frame so i was just wondering if it was worth it to get it
10-28-2009, 12:17 PM | #5 |
A 71-72 will have front disc brakes, others will have drums.
Short wheelbase is 115" and I think the blazer is 105". |
10-28-2009, 12:57 PM | #6 |
I know of one of these running around town out here, If I can run him down I'll try to get the skinny on it, Its a 4WD with a 4-6in lift dark green/white, really sharp looking. He used the Blazer rear quarters to make his super shortbed, so it has the gas filler in the same place as a Blazer but it has an actual bed and cab on it, if I am making any sense...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 10-28-2009 at 12:57 PM. |
10-28-2009, 01:14 PM | #7 |
blazer wheelbase = 104
10-28-2009, 01:25 PM | #8 |
Suburban Hick
My cousin built a 4x4 long box frame out of rear leaf spring 2wd frame and the front half of the blazer frame. I think he basically sectioned it where approximatley the middle of the cab would be. Hopefully someon will chime in on this, but i think the front blazer body mounts are in the same location as the front cab mounts on a truck.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
10-28-2009, 02:49 PM | #9 |
So I guess you would wind up with a 5 foot 2 in bed? Using a blazer chassis? But wait the body bushing location wouldnt line up would they?
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
10-28-2009, 07:38 PM | #10 |
I made a plow using a Blazer frame. I installed rear cab mounts so the cab could be bolted to the frame and made a home made bed out of oak boards. It is really short but I need something short for plowing around my buildings.
Here is a picture of it. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-29-2009, 10:10 AM | #11 |
Thats a cool little bobtail! Does it work good for ya? I bet you have to put a bunch of weight on that little flatbed huh?
10-29-2009, 10:20 AM | #12 |
If you lengthen the frame you should have any problems and I would think that would be alot easier that shortening everything else.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
10-29-2009, 10:33 AM | #13 | |
Lengthen the frame: Weld a section to an integral structural part of the vehicle. Lengthen the brake lines. Lengthen the e-brake cable. Lengthen the fuel lines. New longer driveshaft. Shorten the bed: Cut a section and re-weld bedsides and floor. Body work and paint. |
10-30-2009, 12:24 AM | #14 |
so ya i guess i could do some cool stuff with it if i got it but it wouldn't be bad since he is wanting to trade anyway and it wouldnt take any money for my other projects for now, god knows i have enough and i almost have the 69 on the road
