Are all frames the same?
I have a 67 k10. I am going to be swapping to a newer frame. I believe it is a 72. The vin is 2ZXXXXXX (72, fremont, # built). The frame has an 8 lug dana 44 open disk front and an incorrect width dana 60 temporarly in back.
I am wondering how to tell the differences in 1/2 or 3/4 ton frames, springs. or what is the difference if any? Thanks
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
Grease Monkey
Re: Are all frames the same?
I've heard that the 1/2 and 3/4 has different cab mount locations. I also think that the 3/4 frame is build stronger.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
I believe all cabs were the same, but the 4x4 mounts and 3/4t are different than the 1/2t rubber mounts.
I was wondering if the frames were built from bigger channel on 3/4t and if you can tell spring differences by leaf counts. I am wondering if this is a 1/2t frame and springs with 3/4t axles. Im totally ok with that, I just want to know what it is.
![]() Join Date: May 2007
The 72 frame is better.
1) the front springs are the same,both can have two or three spring pack. 2) the rear will have a bigger spring back and some will have a steel factory lift block 3) the 72 frame should have factory extra bracing for the steering box 4) the channel are the same only 1 ton cab and chassis has a bigger channel for the frame there might be other parts that are different but this is what I know
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
