10-28-2009, 07:59 PM | #1 |
my short bus
69 3 dr ?? before I buy
what are the things to check for in a 69 burb
what are the bad spots for rust to check for frame issues ? other than a jasper 350 and a 3rd row seat that all the info I have to go one going sunday to check it out and possibly buy it quick help needed
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
10-28-2009, 10:16 PM | #2 |
low n' slo
Re: 69 3 dr ?? before I buy
check:
all around the drip rail both rear bottom quarter panels make sure windows are good (hard to find) liftgate and tailgate (hard to find) rockers basically inspect the whole truck for bad rust. some is ok, the areas i listed are usually the most common rust areas, but try to pull up the carpet to check the floor. its hard to know unless you start tearing down.. good luck and be sure to post up some pics!!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-29-2009, 12:02 AM | #3 |
my short bus
got a few pics they sent me body is straight all the way around hood and cowl are the only repaint some damage above driver tail light has barn doors all glass is good no fog small dent in pass fender /grill rocker look great
10-29-2009, 12:24 AM | #4 |
Bowties from Birth
My 68 spent its life in the NE and it was saved only because one of the po's sprayed a bunch of undercoating on the undercarriage.It still has some rust, but not as bad as most that I have seen from this area. Check underneath on the backside of the rockers,the cab mounts and especially at the spare tire well and definitely if you can get a peek under the carpet in the kick panel areas.They are the biggest problem areas.Check the bottoms of your barn doors too. Good Luck!
68 K10 Burb aka "da bomb" 72 C10 SWB Highlander 97 30th anniv. Z28 Conv 99 Chevy Crew 454 11 Traverse AWD |
10-29-2009, 07:18 AM | #5 |
Check carefully inside and out around the windshield pillars and that area of the roof nearby. Very common rust area that is difficult to repair. Another common area is where front floors meet side kick panels. Bottoms of all doors. Good luck. Hope it's good and you get it.
10-29-2009, 06:23 PM | #6 |
my short bus
looks like I not going to look at it till 14-15 of nov so I have some time to research problem area
11-22-2009, 05:14 AM | #7 |
I have been restoring a hard to get parts for an mazda rx2.
I ask this forum about had to get parts for a suburban. This might be useful for you. http://67-72chevytrucks.com/vboard/s...d.php?t=344797 |
11-22-2009, 08:36 AM | #8 |
member
I'm not to far north in Silver Spring Md. I have some extra parts. If you have purchased it, I may be able to help out.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
11-22-2009, 11:38 PM | #9 |
my short bus
yeah I passed on it rust damage all the way around the body
outside looked good but whole floor was rusting off of body at all panels
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** Last edited by 87 dually burb; 11-22-2009 at 11:39 PM. |
