10-29-2009, 02:10 PM | #1 |
choping springs
ok i know its taboo to cut coil springs but i just ordered 3" spindles and i wanna see what 2" off the coil will look like on my truck or if i go 3" so if anyone knows how much to cut off that would be great im not gonna cut the coil with a gas axe im cutting with a angle grinder to help keep heat down!!!!
10-29-2009, 02:17 PM | #2 |
Re: choping springs
Cutting one coil gives about 2". Most of my trucks have cut stock springs and lowered spindles. Just dont cut more than one coil.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
10-29-2009, 02:35 PM | #3 |
Formerly- 1972SuperCheyenne
Re: choping springs
Noth ing "wrong" with cutting coils. Some people may advise against it, but I have had many a truck with cut coils with no issues with ride or anything else. Just keep the head down and just cut one coil.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-29-2009, 02:42 PM | #4 | |
Re: choping springs
Yep - we did 7 or 8 trucks like that back in the day with no issues. My current driver has 23 years and 180,000 miles of "durability testing" with no problems. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-29-2009, 03:08 PM | #5 |
Re: choping springs
thx for the speedy replys so i should cut 1 1/4 coil LOL
OK Another question _ top or bottom i forgot to add my truck was a fatcory diesl if that matters Last edited by 78-5.3; 10-29-2009 at 03:09 PM. |
10-29-2009, 03:32 PM | #6 |
Re: choping springs
only cut the Bottom of the coil.
10-29-2009, 04:01 PM | #7 |
Cruzzzn' Vet
Re: choping springs
10-29-2009, 04:19 PM | #8 |
Master Hater
Re: choping springs
yea , nothing wrong with cutting em, (The right way) and that is to set em in a 5 gallon bucket of water with the coil you want to cut just above the water,cut with a portaband , or a angle grinder, something that cuts quick and doesn't put much heat in the springs.. Heating up springs to drop something is what is taboo.
10-29-2009, 05:36 PM | #9 |
Re: choping springs
while we are on this subject i also ordered the flip kit for the rear i measured the tube 3" and the leafs (8) another 3" for the flip is 6" right i know i can count LOL but that how you work out the flip????
10-29-2009, 06:11 PM | #10 |
Badass
Re: choping springs
a flip is 5ins but i can be more like 6
did you see my truck on finally low. that was a 3in dropspindle and a flip,and i still neeed more drop upfront
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
10-29-2009, 06:29 PM | #11 |
Re: choping springs
10-29-2009, 06:39 PM | #12 |
www.73-87chevytrucks.com
Re: choping springs
Depending on the age of the spring, I generally cut a 1/2 a coil and put it back in and drive it. (remove it by taking the rear lower control arm mounts off) and if that is not enough drop another 1/2 and put it back in and drive it. after a full coil I generally cut around 1/8th off at a time to find tune it. IF you find one side is higher than the other, flip them around.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-29-2009, 08:09 PM | #13 |
Re: choping springs
another thing i was wondering is pinion angle ! and drive shaft length are these altered when you lower a truck 5/7
11-07-2009, 12:14 PM | #15 |
Re: choping springs
11-07-2009, 08:36 PM | #17 |
Happy to be here
Re: choping springs
The springs will probably settle a little. Your going to need a shorter tire once you put the spindles on.
11-07-2009, 09:05 PM | #18 |
Re: choping springs
11-07-2009, 09:47 PM | #19 |
6.0 powered square
Re: choping springs
i have 215/70s about 27" tall on my truck and can barely get my hand to fit in between the inner fender and top of the tire and from the wheel well lip to ground is 24 3/4 for me
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
