Old 10-29-2009, 02:26 PM   #1
sdime95
has anyone done a rear disc brake conversion
i have an 87 2wd swb and im looking for info on doing a rear disc brake conversion. Has any one done it? if so do you have links for parts?
sdime95 is offline   Reply With Quote
Old 10-29-2009, 02:34 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: has anyone done a rear disc brake conversion
I did a swap on my 72 Super Cheyenne. I used 96 Impala SS parts and brackets from Captainfab on the 66 board. I dont know if the brackets will work with a ten bolt rear axle though. My 72 had a twelve bolt. I have also heard of people swapping in an entire rear axle from a Impala SS but I dont know the width difference. I would be interested to know if an Impala axle will work. If so, I know where I will be getting my rear discs from.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-29-2009, 03:35 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can keep the same bolt pattern by using a Caddy or Lincoln rearend. Older cars have disc brakes on the rear. Caddy rearends also correct the 1" travel path between the front and rear tires. You do have to move the perches for mounting.
Conversion kits are also available with Caddy or Vette brakes.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-29-2009, 05:26 PM   #4
Gemp
Gemp's Avatar
94 to 96 Caprice 9C1 (Police pkg) have the same brakes as the Impala SS, and they can be found in the boneyards.
I have a 9c1 parts car I'm parting out,I can measure the rear if you guys need numbers. I'm planing on using the brakes on my 2wd K5.
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 10-29-2009, 05:50 PM   #5
JohnC
JohnC's Avatar
Here is a kit from Blackbirds that a couple of guys on here have used.
blackbirdscustomtrucks.com
JohnC is offline   Reply With Quote
Old 10-30-2009, 08:09 AM   #6
STOCKISH
STOCKISH's Avatar
I would like to know the wheel mounting surface to wheel mounting surface width please.
--Josh
Old 10-30-2009, 09:24 AM   #7
rigon4
rigon4's Avatar
I think the Caprice stuff should work they are a 10 bolt with a 5 on 5 lug pattern would all work nicely i think
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 10-30-2009, 02:47 PM   #8
STOCKISH
STOCKISH's Avatar
Just depends on the width. I already have my wheels and have no plans to change them or run any spacers.
--Josh
Old 10-29-2009, 06:59 PM   #9
sdime95
does anyone have pics of there conversions
Old 10-29-2009, 07:58 PM   #10
watahyahknow
watahyahknow's Avatar
dont think there a lot of step by step instalations photos you might try the people selling those kits to look for buildlogs on there website
i seen a couple on pirate sumtin its a 4x4 website and a bit hard to navigate it seems pretty simple take out the axles remove the backingplates for the drumbrakes and install the diskbrake adapter replace the axles and mount disks on them the mount calipers and mount new brakelines and emergency brake cables if these aply to the kit .
the only thing that might take some thinking is the clocking of the calipers (top front or back on the disk ) the bleedernipple of the caliper should be on the top end spacing the adapter so the caliper is somewhat centered over the disk
another thing you might want to check is if youre wheels will still fit with the diskbrakes there usually bigger in diameter and stick out a bit more towarth the wheel
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-29-2009, 08:02 PM   #11
menace121978
menace121978's Avatar
there's a ton of pics in the 1st 5 pages of my build thread... Blackbirds!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
