10-29-2009, 10:26 PM | #1 |
Lights
i have an 82 c10 when i pull on the light switch the dome light comes on no dash lights or parking lights then pull the headlights on the dome light still stays on blinkers still work could this be the switch
Drive It Like Ya Stole It '82 Primer White c10 2wd LWB 350 sbc t350 (Hot Rod) '90 2wd LWB Silverado 350 tbi 700R4 (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
10-30-2009, 08:20 AM | #2 |
Don't Crush em Restore em
Re: Lights
Just went through this myself, you need a new headlight switch, got my at Oreilly's for like $30 bucks. The only trick to changing it out is getting the knob off, there is a button on the top of the switch that need to be depressed as you pull on the knob, and the shoaft should pull out of the switch.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
10-30-2009, 09:16 AM | #3 |
6.0 powered square
Re: Lights
just ask for a universal gm headlight switch its the same thing and about 10 dollars cheaper
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-30-2009, 06:27 PM | #4 |
Re: Lights
didnt work guys
10-30-2009, 09:15 PM | #5 |
Re: Lights
Well done some testing with an wire and i could do all the lighting (headlights,parking lights,gauge lights,dome light ) manually by hooking it to each wire in the plug to the hot wire it all worked made a hot wire to the dome light and it works good better than before more than likely a short cause its a new switch
