![]() Join Date: Jan 2009
03 truck turn signals wont work
when i first bought my truck the turn signals worked intermitantly. Almost always in the morning they wouldnt work then id get off work and they would work all the sudden.
I had called the previous owner to see if there was something i needed to know about it and he said just to blow some dust cleaner in the fuse box. Never helped the problem. Anyone have any ideas what could be keeping my turn signals from working. They dont work at all now. |
Re: 03 truck turn signals wont work
shot in the dark, do your hazzard lights work? if not replace the flasher unit, not sure where they are in your truck though
changed the hazard flasher relay, still no turn signals. anyone else have any ideas?
I wouldnt even know where to start looking for bad ground wires
maybe bad ground wire?
if it is still under warranty take it to dealer and have them fix it Last edited by tecky11; 10-30-2009 at 04:40 PM. |
Probably the turn signal switch/multifunction switch. have you checked all the fuses?
Windy Corner of a Dirty Street
X2
Had to change the multifunction switch on my niece’s 1999 Olds Aurora last weekend for the same intermittent turn signal issue. Easy to change but be sure you remove all of the airbag fuses before removing the actual bag.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Good idea, how do you go about removing the air bag?
Charlie Daniels w/ a Tq Wrench
Take two cheap BIC pens, pull the ink tubes out, look on the sides of the steering wheel behind the airbag, you will see a small hole on either side. Stick the ink tubes in these little holes and push carefully, it will release two clips that hold the airbag in. Make sure you pull the airbag fuses, and give it about 30 min to make sure the capacitors have discharged.
Did you replace the hazard flasher unit? Or just the relay? My brother's 01 had this problem, where signals would not work, and if he pushed the hazard button the lights would light up solid with no flash. Replaced that unit and it fixed the problem. |
