Old 10-30-2009, 09:41 PM   #1
palposity
palposity's Avatar
Pulling Engine--Need Advice
Hey Guys,
We'll I'm in a bit of a jam. I got my 86 Chevy K20 Plow truck out of moth balls to get ready for the winter season and the engine blew all the oil out of the rear main while I was test driving it. I guess it dry rotted while sitting for the past 6 months. Anyway...the engine is totally seized up. I bought a replacement for it and it is ready to drop in. I was hoping to get the engine out by itself, without the tranny because I've heard it's hard to pull an engine/tranny combo in a 4x4 truck. I've done this in 2wd trucks where I pulled the engine and tranny together no problem. Here is my problem....I can't get a socket on the upper bell housing bolts to save my life! Do you guys have any tricks or special tools that you use? Any help is appreciated. I'm extremely frustrated with this.
Thanks!
Charlie
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 10-30-2009, 09:56 PM   #2
cableguy0
Re: Pulling Engine--Need Advice
either climb in and reach over behind the intake or drop the crossmember and let the trans hang. it will expose the bolts. or just pull the transfer case off and pull the engine and trans together.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-30-2009, 11:07 PM   #3
palposity
palposity's Avatar
I tried reaching behind the intake from inside the engine bay, but couldn't get enough leverage to turn the wrench. I like the thought of dropping the crossmember to tilt the tranny back. I may have to give that a try!
Old 10-30-2009, 11:11 PM   #4
bitchin85
bitchin85's Avatar
thats what i just did to mine, take out the cross member and unbolt your exhaust from your headers, or manifolds, and tilt the motor all the way back and you will easily be able to get a socket on it with a swivel and extension. REMEMBER to take off your distributor cap before you tip the motor all the way back because it will hit the fire wall and break it. good luck
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 10-31-2009, 11:26 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Is it a manual or an automatic?
When I yanked mine I unbolted the bell housing from the manual transmission and left the trans & transfer case in place.
Yanking the distributor will make getting to the top two bolts much easier. A 9/16 box end wrench with another wrench hooked through the open end will make you a tight clearance breaker bar if you need it.
68 TT is offline   Reply With Quote
Old 10-31-2009, 10:15 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Before you drop the crossmember, try a long extension with a swivel. It might save you some time.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-31-2009, 12:26 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive always been able to get those bolts with my four foot extension and a swivel socket with the 9/16 socket all 3/8 drive
make sure you disconnect the torque converter too and push it as far into the trans before you yank the motor... the first time i did a solo motor i forgot that step and wound up goin for a trans too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-31-2009, 08:53 PM   #8
palposity
palposity's Avatar
Thanks for all the tips guys! I ended up buying a swivel and long extensions and that got the job done. I'm concerned about the torque converter thing. I tried to pull that off the flywheel before pulling the motor, but my engine was so badly seized up that I didn't have a prayer of rotating the fly wheel in order to get all 3 of the torque converter bolts off. How do I know if I ruined my tranny? (besides trying to put it in gear when I get it all put back together)
Old 10-31-2009, 08:55 PM   #9
cableguy0
you wont hurt the trans simply by pulling the torque converter out with the engine. just support the trans as it comes apart so it doesnt fall and slam. just make sure you fully seat the torque converter back onto the trans before you try to bolt another engine up.
Old 10-31-2009, 10:25 PM   #10
old Rusty C10
I beg to disagree with cableguy.. he is correct if you have the complete nose off the truck and pull it forward, but if youre trying to get the motor out with the radiator support in , you wont have enough room and the shaft will damage the seals and bearings in the front of the trans... this happened to me.. i found out after i started the new motor and trans seal started leaking
this all happened on a 350 motor th350 trans in a 1978 camaro i was working on back in the day
Bob
I hate cancer!!
Old 10-31-2009, 10:28 PM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Swival joint and three/four long extentions!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-31-2009, 10:46 PM   #12
cableguy0
so long as the converter snout clears the trans its fine.if you try lifting the engine with only the converter engaged yes it probably will tear up the pump bushing and seal but the converter snout is only 3 inches or so. its a pain to get out but can be done without damage. the only thing that can really get hurt is the bushing and seal both replaceable without tearing the trans apart
Old 11-01-2009, 10:38 AM   #13
68 TT
68 TT's Avatar
If you can't unbolt the converter then it is best to not take the chance of damaging the front pump bushing, seal or converter snout and just pull the engine and trans together.
You can leave the transfer case and extension housing in place just make sure you support it well so it doesn't tip and break something. There is nothing to hurt in that connection and it is pretty easy to get back together.
It will be very messy as trans fluid will freely flow out the back.
Old 11-01-2009, 02:20 PM   #14
palposity
palposity's Avatar
So since I have already pulled the motor independent of the transmission (I had a jack under the tranny to support it) It probably wouldn't be a bad idea for me to replace the front bushing and seal in the tranny before installing the new motor? If I am understanding you correctly hopefully everyone agree's all should be well.
Old 11-01-2009, 02:43 PM   #15
cableguy0
the seal and bushing are probably worn anyhow. look at the bushing. it will show its wear if there is any. the seal is easy to replace but the bushing is a pain bc of the input shaft being in the way.
Old 11-01-2009, 03:01 PM   #16
palposity
palposity's Avatar
Thanks. Do you have to pull the tranny to replace the bushing?
Old 11-01-2009, 04:03 PM   #17
cableguy0
not with the engine out of the way. you can get it. but its probably not completely needed. your definately not the first guy to have the same dillemma with a locked up engine that pulled it out that way.
Old 11-01-2009, 04:02 PM   #18
old Rusty C10
with the motor out you can prolly do it... i replaced the whole trans as it was a 2wd car not a 4wd truck
Bob
I hate cancer!!
Old 11-02-2009, 09:08 AM   #19
palposity
palposity's Avatar
Sounds good. I just need to figure out the particulars about what Transmission I have so I can get the right seal/bushing. The pan says "Hydromatic" on it. Is that enough info?
Old 11-02-2009, 10:54 AM   #20
chicklin
chicklin's Avatar
Being a C10 it's most likely a TH350, unless it's been swapped in the past.
1954 Chevy 3600 - 235, 4-spd
1986 Chevy Suburban - 350, 700R4
chicklin is offline   Reply With Quote
Old 11-02-2009, 11:11 AM   #21
palposity
palposity's Avatar
The truck is my K20.
Old 11-02-2009, 12:20 PM   #22
68 TT
68 TT's Avatar
Should be a T-400 then. Is the pan square with a corner cut off or an irregular shape?
Irregular shape is the T-400. Square is the T-350.
Old 11-02-2009, 08:03 PM   #23
palposity
palposity's Avatar
I got under the truck and took another look at the tranny pan. It only has one normal looking corner...the rest of the corners are very irregular...so I am guessing I have a T400.
Old 11-02-2009, 12:38 PM   #24
chicklin
chicklin's Avatar
Ooops, my bad. Yeah, like the other guy said, should be the TH400.
Old 11-02-2009, 08:41 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
This should help
Articles-
"Refining Sierra"
