![]() Join Date: Apr 2008
Is my DOM too thick?
I am in process of converting a C20 to C10 and getting rid of the rear leaf springs. I am building my own set of trailing arms too. Never could find a thickness from any of these companies that sell trailing arm kits, they only described them as heavy wall DOM tubing. So I bought some 2" x .250 wall DOM tubing notched and welded bushing ends, and got some soft polyurethane bushings.
Now I am starting to think that the tubing might be over kill and will not flex enough, and cause the bushing and weld to take the brunt of the torsion. I know that that is the bushings job but the original trailing arm was able to twist more, relieving the crush factor on the bushing. Also since I went with poly bushings they are a bit stiffer than the rubber so this in turn is going to add quite a bit of torsion to the weld. I am confident in my welding ability, but the more I think about it I don't want to add repetitive strain day in and day out, plus I don't want to have to replace worn out bushings every 20,000 mi. Where if I went to a thinner DOM that has a little flex in it might solve some problems in the future. I would appreciate some advice, am I thinking about it too much or is it just too stiff. Sorry the images kind of suck, only had a cell phone on hand.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Re: Is my DOM too thick?
Overkill is good. I personnally wouldn't want my link bar to flex any at all, I think you'll be fine. I use 1.5" OD .25" wall DOM for most all my stuff.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 10-31-2009 at 04:13 PM. |
flexing bars is bad.
why would you want any of it to flex, its not a 4x4/crawler, flat and stiff is street and fast. |
you are right on the money about the stock 2 pc. trailing arms being designed to flex ... that's the reason they are riveted together as opposed to being welded ... for what it's worth
i think everyone will have a different answer to this question, but suicide doors link bars ar made from 3/16". my link bars on my dodge are made of 1/8" DOM, for a none weight bearing (meaning airbag not mounted to it) 1/8" DOM is ok. 1/4 should be fine, probably overkill but will work. Most truck frames (1/2 ton) arent even 3/16" wall...for what its worth
justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 10-31-2009 at 07:24 PM. |
This is what I was thinking, I would rather be a bit to overkill than a bit to linguine. Since I am still in the design stage I still may cut the joint and put a heim joint in place.
Before I asked my question I did some research and came across many opinions on the forum about Heims and how they make it louder and they tend to wear quicker. But they do make a less binding set-up. I am also planing on mounting Bilstein coil overs to the ends of the arms behind the axle. Thanks for the advice, Any body else?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 10-31-2009 at 11:52 PM. |
Get some currie flex joints or flex joints from suicide doors or from rubicon express.
They are like heims but run a delrin bushing and they are all rebuildable. They wont be as stiff as poly non flex bushings you have now. All those companys sale them and the most expensive ones Ive seen were ballistic fab and they where still under $50 a piece. They have the weld on ends included,all you do is weld up where youre bushing mount is now and your good to go. Hope this helps Last edited by 71'tahoe; 11-01-2009 at 08:45 AM. |
Yes that is exactly what I was thinking about! Thanks, has the flex of a heim and the softness of a bushing. I cut the DOM at 60" for just this reason so if by chance I wanted to change, I could easily cut off the joint and add a different style without wasting $100 in DOM. Just what I was looking for.
The reason I am making my own rather than just buying some is that I am putting this whole system on a Ford 9" (actually Lincoln w/ disc) and every detail has to be somewhat modified so I figured I should just make the whole thing rather than cut up some premade ones. I am going to be installing coil overs behind the axle and I am going to have a 6" drop, so there is no need to have a bend in the trailing arm for a spring perch. It is all shaping up nicely and I totally appreciate all the help.
They are the best way to go. As far as the bend in the arm are you talking about in the arm,that is there for the angle of the arms. if you were to draw a line from the center of the mount on the chassis to the center of the axle the angle would be pretty drastic. So to correct the pinion angle of the rear axle and to not have such a drastic angle the factory added the angle to the arms. You can try to run your home made arms stright from the chassis mount but then you have a huge angle.
