Old 11-01-2009, 05:21 PM   #1
MrTucker
MrTucker's Avatar
What are the differences between GMC and Chevy AD frames?
I have a 1953 GMC 1/2 ton long bed with a slightly twisted frame. I've read on Stovebolt and OldGMCTrucks and I know that there are differences between GMC and Chevy frames - specifically in the radiator support area to compensate for the longer/larger GMC motor. What other differences are there?
I'm not planning on keeping the original drive train, instead I'm going with a sbc/th400/MII set up.
I also have a line on a super cheap Chevy shortbed 1/2 ton frame that I wouldn't mind picking up - if it will work.
thoughts??
MrTucker is offline   Reply With Quote
Old 11-01-2009, 06:14 PM   #2
54 jimmy
54 jimmy's Avatar
Re: What are the differences between GMC and Chevy AD frames?
i think that is the only difference. just grind the rivets off of your rad support and the chevy on and swap them. i almost positive that will work.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 11-06-2009, 04:17 PM   #3
BIGMAC68
BIGMAC68's Avatar
The rear of the frames between the 3/4 ton Chevy and the 1/2 ton GMC are different as well. The 3/4 ton Chevy frame rails are straight back wheras the 1/2 ton GMC frame rails bend outward towards the bed sides after the cab. This makes the bed mounting situation somewhat complicated especially for the rear cross member.
BIGMAC68 is offline   Reply With Quote
Old 11-06-2009, 04:42 PM   #4
Dan Bowles
AD Addict
Both series changed frames in '54 to lower, flatter kicks in order to get a 2" deeper box.
Dan Bowles is offline   Reply With Quote
Old 11-07-2009, 02:29 AM   #5
MrTucker
MrTucker's Avatar
so then are 1/2 ton Chevy frames are the same as 1/2 ton GMC frames???
Old 11-09-2009, 06:15 PM   #6
olBlue
Thumbs up Re: What are the differences between GMC and Chevy AD frames?
In the 1/2 ton frames, the difference between GMC and Chevy is the front frame cross-member.
olBlue is offline   Reply With Quote
