Old 11-02-2009, 03:36 AM   #1
blazer2007
steering column help
have a 80 truck that was a 3 on the tree and I,m changing to a auto ,the new column has different plugs than mine.I don,t know what year it came out off.the flat plug looks ok but the plug at the bottom of the column and the main square ones are different.I wrecked the one on the old shaft,all the little springs came out so I don,t know if you can swap these over or not,hope you can understand this question,is my first column swap
blazer2007 is offline   Reply With Quote
Old 11-02-2009, 09:26 AM   #2
joe231
joe231's Avatar
Re: steering column help
Are the wire colors the same?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-02-2009, 11:43 AM   #3
blazer2007
yes
Old 11-02-2009, 11:48 AM   #4
joe231
joe231's Avatar
You can get a little tool to pop out the connectors from the plugs and swap to the correct plugs.
CHEVY ONLY
Old 11-02-2009, 05:01 PM   #5
blazer2007
another ?,what is the small plug in at the bottom of the steering column just at the firewall,the 3 on the tree one is different than the auto column one,just takes a 3 prong plug I believe
Old 11-02-2009, 05:12 PM   #6
joe231
joe231's Avatar
Neutral safety switch
CHEVY ONLY
Old 11-02-2009, 05:24 PM   #7
blazer2007
should I just change the one from the standard shift column to the auto column
Old 11-02-2009, 05:32 PM   #8
blazer2007
scrap that idea,I broke it.How can I bypass it or rewire it.the auto column has 4 prongs and the standard one had only 2
Old 11-02-2009, 11:56 PM   #9
joe231
joe231's Avatar
You really don't want to bypass it
it is a safety there for a reason
find you a junk yard and get one and the correct plug.
CHEVY ONLY
Old 11-03-2009, 11:43 AM   #10
blazer2007
I just want to be able to start it so I can move it until I find the part
