Old 11-02-2009, 08:31 PM   #1
rogergodding
rogergodding's Avatar
The old "best" starter to use topic....
I've searched the archive a bit.... but still haven't found what I want to read. Anyway, my starter (solenoid ?) has had issues with cranking after a long ride. It seems to be getting worse (not so long ride). What is the best, least expensive solution? It has a Hi-Lo/Oreilly auto parts "lifetime" guaranteed starter on it, I think.....
rg
rogergodding is offline   Reply With Quote
Old 11-02-2009, 08:41 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: The old "best" starter to use topic....
"Lifetime" guarantee starters from parts stores are junk. You will be taking it off and replacing it every three months for life. Take it to a local shop that rebuilds in-house, or get a mini-starter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-02-2009, 08:47 PM   #3
rogergodding
forgot to mention, that I've had this starter since about 2000.....
Old 11-02-2009, 08:51 PM   #4
rogergodding
OK, maybe what I am looking for is your experience with mini starters (skip white ebay?), etc.... don't have much to spend at this time, but need my baby to start......
Old 11-02-2009, 09:05 PM   #5
mixermike
mixermike's Avatar
summit racing mini starters have never let me down in either my small block or my big block
mixermike is offline   Reply With Quote
Old 11-02-2009, 09:05 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Wow...you are lucky! If it lasted that long, pull it off and exchange it for another one. I had my alternator and starter built by a local shop. No problems ever. I like the mini starter cause it sounds bad a$$ when I crank it, and it only weighs 8 lbs as opposed to about 30.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-02-2009, 09:10 PM   #7
rogergodding
Yeah, I guess they might still have the info in the system to replace it.. not sure where that receipt would be these days...... that starter has been used on 3 engines now......
Old 11-02-2009, 08:42 PM   #8
67sss
67sss's Avatar
start with the easy stuff first. make sure your battery and charging system is working good, check the ground of the battery to make sure it is well grounded. then climb underneath to pull the starter off and have it checked if none of the easy steps helped.
67sss is offline   Reply With Quote
Old 11-02-2009, 08:42 PM   #9
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Talking Re: The old "best" starter to use topic....
If you want least then get a shield for it or wrap it with the heat reflect they sell.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 11-02-2009, 09:20 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
what does yours do, mine feels like i dont have enough juice to turn the motor over? wtf, maybe i should have my batt. checked someday..
John
1999 Toyota Tacoma 4x4
Old 11-02-2009, 09:49 PM   #11
rogergodding
when the starter is hot, it does not turn over or "acts" like it doesn't want to..... My battery is putting out over 12 volts while this is happening....
Old 11-02-2009, 09:22 PM   #12
watahyahknow
watahyahknow's Avatar
think a rebuild would be enough i done those myself for a living and if there good they replace all bearings ,the solenoid inners ,the brushes and recut the eeeh not sure about the english word for it the stator i think replace the sprocket in the nose and paint before reassemble we trew all aloy parts in a polisher after dissasembly wish hardened the metal some and gave it a like new finish
the wire inside usually last more than a lifetime if it isnt burned up by verry long startcycles the stuff that wears our is the stator and the brushes and the copper contacts on the solenoid .
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-02-2009, 09:31 PM   #13
WIDESIDE72
WIDESIDE72's Avatar
I am running some sort of AC Delco gear reduction starter on my 383 stroker. I am not sure of the originl app, but it hasnt let me down in 5 yrs, even in 100+ plus Texas heat. I relocated the battery to the trunk, and when I did, I had some 3/0 welding cable from my dad who is a retired welder and ran that from the battery to the starter. I think that makes a big difference.
WIDESIDE72 is offline   Reply With Quote
Old 11-03-2009, 12:13 AM   #14
clinebarger
If it looks like this its a 92-96 corvette starter, requires a small flywheel. Very good starter.
clinebarger is offline   Reply With Quote
Old 11-03-2009, 09:33 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
Yep, that's it!
Old 11-02-2009, 09:31 PM   #16
fjthompsoniii
I've had really good luck with the ac delco they cost more but I think you get what you pay for. If you order one for a 1970 i believe is the year they changed you'll even get a steel nose instead of aluminum.... bulletproof!
fjthompsoniii is offline   Reply With Quote
Old 11-02-2009, 09:32 PM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd disassemble the solenoid and turn the big copper washer over. That will make it ready for another 10 years of use. No sense buying a new solenoid or starter just because the contact washer is arced up.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-02-2009, 09:35 PM   #18
cdowns
cdowns's Avatar
chrome ones start bestest
Old 11-02-2009, 09:55 PM   #19
watahyahknow
called heatsink and i heared that before they usually solve that by using a remote ford solenoid mounted on the firewall
Old 11-02-2009, 10:06 PM   #20
rogergodding
saw those posts.... hoping that a mini would be the solution...... will need to get this fixed soon... just drove about 15 miles today, side streets.. stopped at 7/11 and it would not start for a bit...
Old 11-02-2009, 10:12 PM   #21
Sinister
Between Trucks...
Sinister's Avatar
x2
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-03-2009, 09:40 PM   #22
WIDESIDE72
WIDESIDE72's Avatar
Heat SOAK, actually-Simple terms - a hunk of metal (or other thing) starts out at ambient temperature. It's exposed to other another temperature that warms (or cools) the surface. As time goes on, the head (or cold) evens out throughout the metal and the thing is "heat soaked". If you take away the source of the heat (or cold), the part will remain hot (or cold) for quite some time as it gives off the heat (or cold) that has "soaked" in the metal.
A heat sink (or heatsink) is an environment or object that absorbs and dissipates heat from another object using thermal contact (either direct or radiant). Heat sinks are used in a wide range of applications wherever efficient heat dissipation is required; major examples include refrigeration, heat engines, cooling electronic devices and lasers. (A Heat SINK would actually help in this instance).
Old 11-02-2009, 10:14 PM   #23
watahyahknow
think a heatshield would solve it too it usually happens when running headers , thats not too expensive to try .
the heatsink thing is the metal round bar thats inside the solenoid heating up and sticking a bit making less contact than usual so the heatshield schould only need to cover the solenoid
when the heatsink thing is realy bad it sumtimes helps to tap on the solenoid with a piece of steel (dont hit the battery hookups though or there be sparks flying )
Old 11-02-2009, 11:07 PM   #24
rogergodding
thought about a heatshield, but since the problem seems to have worsened quickly..... thinking it may be too late for that...
Old 11-02-2009, 11:15 PM   #25
hayhauler71
hayhauler71's Avatar
I had the same hot start problem in my 71 with a 350 with headers. I went with the combo meal, new summit gear reduction starter with a heat rap plus the remote solenoid. So far so good.
hayhauler71 is offline   Reply With Quote
