383 stroker or big block
I'm thinking of doing my 350 into a stroker or should I try and get a big block. What's your guys take on this one?
Big Block!
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Big Block!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
STROKE IT!
No offense Larry, I am a small block nut! Sam
72 LWB chevy truck. Pasadena, Texas |
Fabricate till you "puke"
I have done both, & that little 383 is a runnin SOB......but its not a BB!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
383 cheaper. . . . . . .
Cantankerous Geezer
383 is a good runner and cheaper to build, but a big block is the way to go if you can afford it. You can't beat cubic inches for more power!
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Seņor Member
Big block AND stroke it. 540? 602? 632? Yeah!!!
Kenneth
Got earplugs?
As it says below, why would you have anything other than a big block. Can't beat the sound!
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
Man this post must of attracted bb fans, there must be some 383 lovers out there, I need pros and cons. Will a bb drop right in my 71 4x4
383 cheaper, you can build 3 of these for what one bb will cost you
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
![]() Join Date: Nov 2002
What's your intended use?
BB for pulling and all out racing, 383 for everything else. ![]() Jeff
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
i love summertime
bb
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
truckstr every day use , but I love to giver now and then love G force
#15 |
383
less$, less weight, fewer headaches getting accessories
Orion 80K10Scottsdale 350/th350/205 d44/14bff locked 35's 97 blazer 4x4 daily driver |
#16 |
it depends..if you put an eniemic 454 ot of a late 70s truck...you wont be impressed..if you put a un-planned 383 in..you wont be impressed..a little forthought(and money) a 383 will supply the wanted G's..more so than a smogger 454..but a crate 454 or 502 stock out of the box will impress you and it will have a warrenty. If I had 3500-4000..sitting here..I dont think I could make an argument as to why to not go new big block...to make the same HP out of a 383,as a 500 hp 502, it would take atleast that much money...and in no way would it have a warrenty.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#17 |
We Sell Truck Parts
Big block!!!!!!!!!!! I have had both and big block life is good! Why does every one think a big block cost more? The only thing I have seen that cost more is alum. heads.
'67 Chevy SWB 454/400 '97 Chevy Tahoe 4x4 '62 MG Midget |
#18 |
Got Big Block?
money no object Big Block. otherwise 383. I LOVE mine, but I still dream about my old 427. Must be a guy thing.
"Experience is what you get when you didn't get what you wanted." |
#19 |
casey,
If your going for everyday use (and, to me, that insinuates that you want BOTH reliability & gas mileage) AND you also want to pull some "G force", then it's almost a toss up. I've had and been around big blocks. The newest variety (502 crate motors, etc.) - with the new style heads and valvetrain - will cost less to maintain. The warranty is a BIG selling point with the crate motors. But (there's that "qualifier"), ya have to keep it all in perspective. What are YOU wanting out of the set-up? Everybody here has their own likes and dislikes, but - in the end - they won't be living with the decision, YOU will. On a budget, small blocks (not necessarily 383's) tend to cost less to build and maintain. If, however, you can get all of the accessories and brackets, etc., cost effectively, then a big block crate engine may be just as cost effective. It all depends upon YOU. Good Luck, Jeff ![]()
#20 |
Ain't we cute?
Well, either way you go you will love the difference. What tranny do you have? What rear gears? Need more info!
But here goes anyway. ![]() For cheap fun that CAN be economical, can't beat a stroker small block. If you take your time, you may be able to get a mild BB setup for not too much more. Nothing feels like BB torque (except stout LS1s) but for speed, you may end up same/same depending on your drivetrain. Get you an OD tranny to compensate for MPG loss. Even EFI is an option if you take your time and shop hard, TBI especially.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 ![]() |
#21 |
build a 454 or 427 small block they built bothin this hot rod book i got fr christmas on big inch strokers for small chevy. its like 6-7 hundred horse
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
#22 |
72 LONGHORN OWNER
383.........................
#23 |
Does a big block need higher octane gas than a 383 would?
If a woodchock would chuck wood? |
#24 |
registered IWATA user
well this all come down to a simple run through of the truck alphabet......
"A" is for alternator "B" is for BIG BLOCK "C" is for CUBIC INCHES thats two out of the first three that say to get a BB
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
#25 |
My other Love
Well I have both. I have a ls6 454 in the 69 cst. I have a 383 in the Monte. I get way better gas milage on the monte then I would ever get on the 69. The 69 just has way more figgen torque. I would have to say for a daily driver a 383 is the way to go, way more affordable and reliable. For all out balls go for a big block.
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
